Question about Acer TravelMate 2300 Notebook
Screen shakes The screen on my laptop shakes and jumps...what is causing this issue at it does it more and more lately!
Violent Shaking
No check engine light on? If it jumps rapidly, then it can only be due to the transmission changing gears, or slipping clutches. Either way, there should be a fault code set in the PCM. You need to get it scanned first to know the fault code.
May 26, 2013 | 2004 Jeep Grand Cherokee
When i shake my laptop, its screes becomes black
Do not shake your laptop.
There are components, like hard disk, graphics card, that are sensitive to shakes.
Jan 29, 2010 | IBM ThinkPad T40 2373 Notebook
My Hp pavillion dv4 notebook pc's screen is flickering quite badly. It happens every few seconds and everything seems to jump up and down once and go back to normal. Tapping or hitting screen or any part...
Flickering is a back light issue, jumping around would be caused by the screens reaction to a bad inverter and so would the backlight as well. So flickering backlight and jumping would be a inverter issue causing both problems so I would replace them both.
Thanks if you like my adivice please rate it with the thumbs and leave feedback!
Dec 19, 2009 | HP Pavilion dv4000 Notebook
The bottom half of my screen is shaking like a "non" TV channel.... I restarted it, and turned it off and back on again and it continued. The shaking occurs every 2 seconds and is spreading higher now. ...
If you can.. Plug a Desktop Monitor into the Serial Port of the Laptop..You do This To See If It Shows Same Thing Onto A Different Screen.. If It Does, You Are Having Video Issues.. Which Were Most Likely Caused From Overheating Issues..
If It Shows Normal On The External Monitor, Yet Still Does Same THing On The Laptops Screen, Then You Have 1 of 2 Issues... Either You Need To Replace The Display Due To A Faulty Circuit Board On The Backside Of The Screen... Or Your Display Cable Is Loose And Needs To Be Fully Plugged Into It's Port, Or The Display Cable Is Failing..
Nov 15, 2009 | Computers & Internet
Dell laptop monitor jumping
Could be your refresh rate. Try the following:
* change your monitors refresh rate to higher availible.
* rt click on desktop then on properties and then display setting and then advance and then click on monitor tab and choose the highest availible and then click ok.
Would also attempt to move the screen forward and back to see if you have a pinched cable.
Also attempt to connect to an external monitor to see if it is your laptop monitor or the video card causing the problem.
Hope this helps.
Oct 25, 2009 | Dell Vostro 1510 Laptop
1998 toyota corolla shakes before 2 rpm, check engine lights up
Not sure what is causing it, but it sounds like you're running on 3 cyllinders. Check plugs, wires, timing . timing belt may have jumped, bad injector, low fuel pressure.
May 13, 2009 | 1998 Toyota Corolla
Blue screen coming up
Have you added any hardware lately? (memory, printer, camera etc) Installing the wrong software can cause this issue. If you installed memory make sure is correct, incompatible memory causes these issues. Check your harddrive is it making unusual "clicking" noises?
Feb 17, 2009 | Dell Vostro 1500 Notebook
HPG60 Laptop - coffee spill - mouse not working
well this is a common thing but most likely the motherboard was shorted out and causing glitching. I would take it to a tech to see if there is anything recoverable in there
Feb 11, 2009 | Computers & Internet
Steering wheel shakes
Sounds like you need a wheel alignment
Jul 29, 2008 | 2003 Lincoln Navigator
Computers & Internet Logo
114 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
