Question about RCA D52W19 52" Rear Projection Television
Will not power on
When holden the power buton in it flashes one time then 9 fast flashes
  • RCA Master
  • 5,138 Answers
Deflection board replace cost 77.99
Posted on Sep 24, 2008
Mx310 makes an alarm sound while the power buton is flashing , any ideas ?
If you use the printer connected to your PC, you should get some error message when you send a print job. If you use the printer as standalone (without PC), count how many times the power LED flashes, then check the Canon website for explanation of the problem. Usually the LED will flash few times than pause before flashing few times...and so on.
good luck with it!
Jun 16, 2015 | Canon PIXMA MX310 All-In-One Printer
How do i set the camshaft timing on wb holden one tonner 1984 model 308 engine?
The cam timing to the crank timing is a bit tricky, it's 9 links from TDC to setup the cam from the oil pump, I suggest you go to your local mechanic and have him set it up, this is something you don't want to stuff up
Jul 31, 2014 | 1973 Holden Ute
Screen seems to be zoomed in large fonts
put your tree fingers together & tap the digitizer 3times very fast an gonna back to normal :}} very funny i know .
or push the home buton 3 time fast
Mar 23, 2014 | Apple iPhone 5c
Getting an error code of flashing 9 times then pause then flashing
Pride Mobility Products Corp Product Owners Manuals Specification Sheets Click on "Celebrity X"
9-flash usually indicates a blown controller. The larger pride scooters are known for blowing controllers and having melt-downs when they are pushed or towed too fast. EVEN WITH THE KEY OFF the controller still monitors the safety systems. If the system detects a "roll-away" situation, the controllers turn on and go into dynamic braking mode in attempt to slow or stop the scooter. If the scooter is being towed or pushed and this happens, the scooter tries to stop the motion, overheats and burns up. Catastrophic failure and 9-flashes will result.
Best regards
Mar 16, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
No sound no picture power buton flashes green for a long time then turns to red and flashes for a long time then solid red
Your power supply will have to be replaced most likely. You can test the power coming out of it with a voltmeter. This is a common problem
Sep 10, 2009 | Panasonic PT-50LC14 50" Rear Projection...
2006 holden vz flashing check power trans on dash
Deffinatley take it to Holden to get it checked... I learnt that the hard way!
Mine was doing that, I let it go for about 5 months as the car was running fine then one day there was a clunk, a splutter and it was dead...
Turned out that the timing chains were worn and eventually slipped, which was when it died...
I hope you dont have the same problem as the repair cost was around $5000...
Sep 02, 2009 | Cars & Trucks
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Rca 53" wont power on, please help
The cicuit board behind the power on and off button needs to be replaced.. good luck everyone
Jan 07, 2009 | RCA D52W19 52" Rear Projection Television
Security Code for Holden Vectra
I rang my holden dealer, they say it will cost $16 and they just go on the internet to look it up. Thats what i'm doing now. They charge you to do the internet search.
Jan 27, 2008 | Radio Communications
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
