Question about Samsung Microwave Ovens
Stopped and seems to have no power now - Samsung Microwave Ovens
  • Samsung Master
  • 9,086 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can order Samsung parts here or you can find your nearest Samsung-authorized service center here.
Posted on Sep 27, 2008
What would cause my Goldstar microwave to stop heating and the tray to stop revolving?
if timer and all other controls seem to work correctly id say a loss of high voltage section in microwave power generation part there can be several reasons for this a profesional serviceman can find more about why ?
Sep 09, 2014 | Microwave Ovens
Samsung microwave se error
see the video attached. God bless you
Dec 09, 2013 | Samsung MS1040BB Microwave Oven
No power - blown fuse?
If it was run without the fan a thermal protect device was more than likely taken out. Check for that and replace the fan.
Mar 25, 2013 | GE Profile Spacemaker XL 1800 36"...
Kitchenaid microwave mondel #KBMS1454RSS seems to have a short somewhere
see the information attached and test the main component for SHORT. God bless you
Sep 24, 2012 | KitchenAid KBMS1454RSS Microwave Oven
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
I have a nn s950 ba microwave. It has stopped
Just a possible solution. Our microwave suddenly seemed deader than a door nail.
Our microwave was on a rolling cart. Without realizing it we had pushed the cart too close to the wall. The cart had pressed the on the wire connection with the plug and temporarily broken the power connection. As soon as pressure was removed from the connection, the microwave came back to life.
May 17, 2009 | Panasonic Microwave Ovens
We have a frigidaire microwave and in the middle of cooking, the motor stopped. The clock and cook time continued to work, but no heat. We've tried using at half power, on defrost, etc. but nothing seems...
What you are saying the microwave stop work like heating,but but the clock counts down.If it is stop heating then there is a rest on or near the magtrogron.Once it cools down it start back heating.Open and close the door will reset power to the magtrogen{sorry about the spelling].Look for loose connector,or replace the click zon it should have a small red buttom on it.
Mar 18, 2009 | Frigidaire Over-the-Range Microwave
Microwave stopped working
Generally, you get something unless the fuse inside is blown. There is generally a fuse inside the unit when you remove the button package. First, make sure that the outlet you have is good. Plug something else into it and see that it works.
Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
198 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
