Question about Sony KP-57WS500 57" Rear Projection Television
Trying to find the fuse and resistor locations
Working on a sony kp57ws500, trying to find the 3.5 a pico fuse location, and the 4.7 watt 1/2 amp resistor locations that go along with replacing the convergence IC's
  • 3 more comments
  • hofacker740 Sep 23, 2008
    Think I found everything. Power up set and picture comes up, no led blinks YEAH...Picture still looks bad, bowed in at top and bottomb and red and blue shadows left and right side. Looks good in the middle though? Any ideas ?
    I replaced one pico that read open, all 30 of my resistors read 1.4-1.6 ohms. Could mine not be 4.7 ohms or is possible that I need to buy and replace all 30 resistors under the heat sinks ?
    BTW thanks for your time and help
    Also powering the set up to see if it worked for a short time won't hurt my new IC's on the D board will it ?
    Nevermind, I just found where you said I have to unsolder one side of every resistor to check it so I will do that. I also hear alot about the pico 5am fuses and caps on the G board ? Better check em also I think !
  • Sony Master
  • 8,617 Answers
Did you replace the picos and check the 4.7 ohm resistors / Thats usually whats wrong when the old ICs go out they take the picos and often some of the resistors as well.
Posted on Sep 23, 2008
Where is the fuse located for the convergence IC for ws65807
There are two 5 amp pico fuses on the same board as the IC the board location jmbers are f(A04 and F9A05 they are solid green and look like a resistor without color bands.
Mar 07, 2010 | Mitsubishi WS-65807 65" Rear Projection...
As I plan to do my convergence repair for my 46" projection tv,resistors are mention to be replace aside from the 2 convergence IC's as well as the 6 pico fuses ( 2 for the G board and 4 for the D board )...
Just replace Both of the STKs but CK all the pico fuses in front and behind STKs they are yellow or green 5amps 6amps For Parts Call Mats Electronic 1-800-628-1118 I have changed out alot and so far have never had to replace any resistors.
Nov 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence parts? What are the specific pico fuses and resistors
There are six 3.15 amp picos use 3.5 amp when replacing and there are two 5 amp picos on the G board the resistors if needed are 4.7 ohm 1/2watt
Sep 06, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Amp repair advice
check on the board to see if there is a resistor that looks similar, 90% of amps amps are matched in there design, meaning the left side is usally a carbon copy of the right, so if you look at one side and there is a resistor that looks like it's in the same spot on the other side, good chance thats the same one, read the colors off the one thats not burnt up. resistors come in different wattages,1/8,1/4 1/2 up to 10 watts, each wattage is a different size, most of the ones you see in the amp are 1/4 watt but some are 1/2 and 1/8. some on the output are 2 to 5 watt, but those are generally 10-18 mm in length, they are big ones you cant miss those. so once you get the color code, read the colors, ex red,gree,brown,last line is either silver or gold, that will tell you the resitor value. then google resistor color codes and then you can match the color sequence with the value codes, and that will tell you the value you need in ohms but then you have to get the size 1/4 watt resistors are generally about 6 mm in legnth, im measuring the actual part of the resistor not including the metal leads, just the body, so if its larger its probally a 1/2 watt if smaller its an 1/8 watt, 1/8 watt are about 4 mm. now go buy the resistor, but you might find it that tough, if its a common value radio shack might have it, but resistors are so cheap, pennies for a handful, good luck on your search.
Jun 30, 2009 | Sony Car Audio & Video
Tripe image, blue, red and green color on image, not focus
you will need to replace the two STK392-560 ICs and also check the 4.7 ohm 1/2 watt resistors and the six 3.5 amp pico fuses.
May 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Sony kp-51ws500 resistors and pico fuses on d board
I can help with the PICOFUSES...they are 4 amp Pico.
As for the resistors, if ANY are burned, look at the convergence amp next to the damaged ones...those resistors are a mirror-image of the damaged ones.
You NORMALLY do not need to replace the resistors, ONLY the picofuses.
Mar 27, 2009 | Sony KP-51WS500 51" Rear Projection...
Samsung pcl5414r power resistors and pico fuses??
Hi again and welcome back to FixYa,
Appreciate the direct "Ask Me'.
Based on your original post, only the STK ICs were replaced. Presumably 392-040, the surrounding resistors and pico fuses could very well have been affected as well. Depending on the board revision (pls confirm location numbering on the actual board), the resistors could be:
RZ104 -RZ106 - 270 Ohm 1/2watt
RZ133-RZ135 - 27K Ohm 1/16 watt
RZ136 & RZ138 - 3.3K Ohm 1/8 watt
RZ146 and RZ147 - 3.9 Ohm 2 watt
RZ148 and RZ149 - 150 Ohm 2 watt
while the pico fuses would look like the image below.
Good luck and Thank you for using FixYa.
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Mitsuibishi WS65809
The only items on your set that should need replacement would be both convergence IC IC801 and IC802 which are both STK392-570 and you will also need to change the two 5 Amp pico fuses which are F9A04 and F9A05 they are both % amp pico fuses. All parts are located on the center Board
Oct 23, 2008 | Televison & Video
Sony KP-61XBR200 Convergence problem
STK392-020 ICs are the convergence ICs for your model, you may also want to check the 3.5 amp pico fuses and the 4.7 ohm 1/2 watt resistors as well.
Aug 16, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
KP-57WS500
If you look at the Convergence ICs you will notice a row of resistors under the fins of the heat sink. Those are the 4.7 ohm resistors. Also in that same row of resistors you will notice the 6 yellow picos they are all lined up the picos have 4 grouped together then 1 more on each end of that row or resistors.
Jun 21, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
217 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
