Question about Frigidaire Washing Machines
Washing machine fills up with water, washes, but does not drain. Owner pushes knob in, and turns... still does not spin
    Sniper:
  • 88 Answers
I can't say for sure, especially without a model number....but I would check the lid switch.
Posted on Sep 22, 2008
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Kenmore 70 Series Washer Won't advance in the
    Bad timer. Try to find a used one if possible, this item is a little expensive.
    Aug 23, 2010 | Kenmore Washing Machines
    Machine fills with water and then the water just sits there. The only way the machine will do anything is if I turn the knob to drain and spin the water will drain and the machine will spin. Please advise.
    Need a model but check the lid switch on right side a little opening under the lid. push with a small screw driver and see if you hear a click, maybe a bad lid switch.
    May 19, 2010 | Washing Machines
    My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
    Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
    Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
    Washing machine wont wash or spin, just fills and drains
    THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
    Apr 24, 2009 | Washing Machines
    Frigidaire washing machine gets stuck on cycles
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Apr 01, 2009 | Frigidaire Washing Machines
    Washer will not cycle
    Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
    Washing Machines Logo
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
