Question about Shuttle Computers & Internet
My daughter has a Shuttle computer case with clear sides. It has a CE stamped on the back with a serial # L3674030504780. I'm trying to find a larger power supply that will fit into the small case. The current power supply is 220 volts and has problems running the Sims and or Spores games. The monitor keeps periodicly blacking out for just a moment and then comes back on. I took the computer to Frye's and they said it was the power supply and it needs to be increased to at least 300 watts. Can you please help me find a power supply that will fit inside the case? Thank you, Steve stephen@fpicom.com
McIndia
  • 131 Answers
SOURCE: Emonster 600 won't boot up
Remove the ram and reinstall it.
Posted on Jan 03, 2008
thalal
SOURCE: Power Supply
Use HP D530 power supply to run SSF desktop which can run on 12v dC current. Just by using one 6000VA in series
Agent Aaron
  • 265 Answers
SOURCE: case for gateway 310s series
Hey jbulldogst,
According to information provided by the manufacturer, the Gateway 310S (2900621) uses a 4-bay micro tower.
If you'd like any additional information on the original factory specifications, I've provided a link to Gateway's support page below:
http://support.gateway.com/s/PC/310_Series/2900621/2900621sp4.shtml
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 16, 2008
worldvet
  • 859 Answers
SOURCE: i took nero 7 off
hello,
You need to clean up after and uninstall of almost all Nero suites.
{thanks to support at Nero for this}
Nero 7 CleanToolUninstalling Nero7 did not work correctly? Use Nero 7 CleanTool to delete all Nero 7 entries from your system.
More Details and Download Step 1:For a later reinstallation of Nero 7 it is necessary that you find and note your serial number before uninstalling Nero.
You will find your serial number as follows:
  1. Launch Nero StartSmart.
  2. To do so, double-click the icon "Nero StartSmart" on your desktop.If you do not have a shortcut to Nero StartSmart on your desktop, openNero StartSmart as follows: Click "Start" in the Windows start menu.Subsequently click the entries "All Programs"-"Nero 7”-"Nero ToolKit" -“Nero ControlCenter”.
  3. Nero Control Center will open. Click the "Licence" icon on the left side to see your serial number
  4. Your serial number is displayed in the window on the right.
  5. Please write down your serial number.
Alternatively, you can also find your serial number in the Windows registry.
Please proceed as follows:
  1. Click "Start" in the Windows start menu.
  2. Click the "Run" command.
  3. The window "Run" will open. Enter "regedit" in the "Open" text field and click the "OK" button.
  4. The registry window will open. You will find your serial number on the left side in the navigation tree.
    Simply go into the path: HKEY_LOCAL_MACHINESoftwareaheadInstallationFamiliesNero 7Info
  5. Your serial number is displayed next to the "Serial7" entry. It is structured as follows:
    Retail version: 1Cxx-xxxx-xxxx-...
    Nero Essentials: 4Cxx-xxxx-xxxx-...
  6. Please write down your serial number.
Step 2:Now start uninstalling all Nero 7 applications from your computer using the Nero 7 CleanTool.
  1. Download the Nero 7 CleanTool, save this file to your desktop.
  2. Unzip the ZIP-file with WinZip or WinRAR and save the content to your hard drive.
  3. Double-click on the unzipped EXE-file to start the CleanTool. Thewindow “Nero General Clean Tool” will open. The installed Nero versionwill be displayed.
  4. Activate the checkboxes in the displayed Nero version.
  5. Then click the “Clean” button. A status window will open. The execution of the tool may take several minutes.
  6. Please wait until the progress bar has moved completely to the right.
  7. In the window “Nero General Clean Tool” click the “Exit” button as soon as the erasing procedure is completed.
  8. Reboot your computer. The Nero 7 CleanTool has removed all Nero entries from your
Now click here to download the clean up tool.
Don't forget to reboot and before installing again run your system defrag under driver/properties/tools/defrag
Any questions and feedback, use the comment box below.
For example, have you upgraded to XPSP3 or VistaSP1? Press at the same time Windows Logo Key + Pause at the same time. The information is in the top right area.
Regards,
Worldvet
Posted on Aug 21, 2008
jvernice
  • 63 Answers
SOURCE: hp compaq d530 400 watt power supply
You will not find a power supply for this case. Why would you want to upgrade such an old computer? Get yourself a new one with amply power for your needs. If you are one that upgrades regularly, get a standard case with standard components that can be upgraded without the hassle of replacing proprietary form-factor compnents.
Posted on Aug 02, 2009
Ce-200
Is the Bobbin the right size for the machine? That may keep the bobbin case from latching properly, causing this phenomenon. Shuttle latched in properly? Machine cleaned and oiled per the manual? Make sure bobbin is wound straight and correctly... Post with results or follow up questions
Dec 30, 2013 | White Sewing 2037 Mechanical Sewing...
I have acquired a casio CE 3700 without a manual and need to change the company name that is printing on the receipts - please help
A very rare but great machine. You need to pull the stamp out from the back of the receipt side of the printer (there is a small black handle that you pull just under the paper entry). Then take the stamp to a stamp maker to get your name, tax number etc cut into a new stamp.
If anyone is looking for a Casio CE-3700 manual, there is a user and programming manual here: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_operators_and_programming_manual.html
Oct 11, 2010 | Casio Parts Cash Register PC Desktop
Bobbin case keeps popping out of my CE-100 Futura. Not sure whether or not the case is in there correctly.
Raise the needle to it's highest position and the case should go right into the shuttle.
Refer to the maintenance section of the manual for your machine.
If you do not have a manual, you can get one at the Brother website.
Apr 01, 2010 | Singer CE-100 Futura Computerized Sewing...
Ce-350 i cannot get bobbin holder back in
Raise the needle to it's highest point and the bobbin case should snap back into the shuttle.
Mar 12, 2010 | Singer CE350
My brother CE 4000 sewing machine freezes. After some tinkering I can sew a little then in happens again. It makes a shuddering noise then freezes and shows an E6 error message?
Turn off the power and remove the needle and presser foot.
Remove the needle plate, bobbin and bobbin case.
Clean the shuttle and surrounding area.
Replace everything.
Make sure the flat side of the needle faces to the back of the machine.
Raise the presser foot and re-thread the machine.
Mar 06, 2010 | Brother Sewing Machines
I need the radio code for a Renault Megane Scenic 2001 serial code: JA0D0524452251
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
There should be a 14 character Serial Number beginning with  RN  or similar (often found stamped in the metal casing ) and maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find
Sep 25, 2009 | Vehicle Parts & Accessories
I have a 15212 model sewing machine & have hardly used it. When sewing the other day a few stitches went out of the fabric and got stuck. I opened the shuttle assembly, cleared the tangled thread and...
Sorry to say but one of your steps is incorrect. Look at it again, take a deep breath and gom
over everything slooowly. If this really doesn't work then Im afraid it's a technician you need :) .
Apr 27, 2017 | Kenmore 15202 Mechanical Sewing Machine
Error 058 Shuttle Jam on an IBM 6400 Matrix printer
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | IBM 6400 Matrix Printer
Can you replace a XPC Shuttle power supply with iStarUSA CP01040?
I did exactly the same for a build I did for someone, but I used the PSU that Shuttle suggested which of course is one of their own, but those boxes are so cramped that a centimeter out will ruin your day.
Depending on which model XPC you have I'd advise you to get a Shuttle SilentX 450W. If you click here you can see which models it fits and all of the techs and specs you need.
Best price I could find it for in the UK is here but also found one in Canada for just over £70. You can see that one by clicking here.
Nov 19, 2008 | Maxdata iStarUSA CP-01040 400W 1U...
Computers & Internet Logo
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
