My lg 32 in plasma tvmodel # 32lc5ocs when going to video in puts and cable inputs reads no signal and cant get my whole menu selection what do i do
  • 196 Answers
SOURCE: Menu, select buttons not working
Try getting a universal remote that would let you get into the menu and change the settings you are thrying to change.
Posted on Feb 09, 2006
SOURCE: JVC GM-P420E Plasma no video green screen
hi don't have the solution for this issue but i'm experiencing exactly the same problem with my JVC GM-P420E : Green screen with all kind of input, the problem is intermittent, it appears more or less after 1/2 hour from switch on .It seems to be related to the thermal conditions ... any help or suggestion is welcome - ottavio
Posted on Sep 22, 2007
osborne382
  • 306 Answers
SOURCE: Component Video Only
sounds like theres a short in side with those connections, (possibly bad installation when it was assembled, may need repaired.
Posted on Nov 12, 2007
davebies
  • 43 Answers
SOURCE: No digital to reciever??
This tv will only output the sound from a digital tv channel through the optical output when using the tv's digital tuner. So if you are connecting a DVD etc it will not output through the optical output on the tv. ONLY digital chanels through the tv's tuner will give you sound. Refer to the tv's owners manual for more info.
Posted on Jan 14, 2008
SOURCE: I can't select TV/Video input on the menu
Prueba poniendo canal 00 en el tv varios modelos de rca entran en modo de auxiliar en este canal.
Posted on Mar 12, 2008
My son used the cord from a kettle for our LG plasma TV (we cant find the TV cord) it isnt working properly. The pixals breakup. I said we needed a audio/video specific cord.Is that right?
Hi if the cord fits the kettle and the television then great, They both run off the same electricity current meaning the electricity won't harm television or cord... Smart kid :)
Mar 19, 2016 | LG Televison & Video
I have a 42 inch panasonic plasma tv, I have great picture and sound on hdmi input only
From a quick look at the tv spec it would seem to cope with most inputs so I wonder if it may be due to input type selection. Mine on some inputs have sub options on its inputs which would be in the screen menu (mine has rca sockets and can become component or normal video input).
You say you can hear sound but no picture which sugests there is a signal of some sort (tv's and video's inputs become live when a video signal is present but if its poor in some way will not show) but allow sound through.
If the game is old then it may not conform to modern standards so present a blank screen. its hard to say what may be the problem but I think input selection or an incompatible signal looks to be a possible answer (if you have your plug ins correct)
Hope this helps.....
Jul 02, 2017 | Panasonic Viera TH-42PZ80U Plasma TV
Pc in problems no signals sony bravia klv-32 ex300
Plug your video cable from your computer into a known working monitor first to make sure the cable / computer video work.
If this works, unplug all cables from your tv, except the power, and plug in the pc video. Make sure to use the menu to select the correct input (should say "pc" unless you are using hdmi cable, then you select the hdmi input (hdmi1, hdmi2, etc).
Mar 02, 2013 | Televison & Video
Itihave an lg tvmodel no 32lh20 iwant to switch from cable to air how do ido this
go to set menu with remote and look for a setting that says cable, air/antenna and switch it but you may likely have to auto program the channels after that.
Nov 01, 2012 | LG 32LG30 32 in. LCD HDTV
My HDMI inputs no longer work. The other inputs are ok. I hooked in a dvd player with HDMI out to make sure it wasn't just my satellite receiver and still it just says no signal. What can I do? Thanks
The only solutions u can tries is to unplug tv,satellite receiver box and plug it back in like about an hour later for the tv to reset itself and the sattellite box receiver to reboot and upgrade it softwares.Than go into the tv Menu go into the video setting and reset the whole tv Tuner signal board.This solutions have great chance for all the HDMI inputs to work again.If not have the same problems,sorry than those HDMI ports on the tv Tuner signal board are shorted and dead.These HDMI ports are putting on by a wave soldering machine when they are put onto the board.These HDMI ports can't be replaced individually or buy parts for it,almost impossible to replaces parts by hand soldering equipments either.The only solution now only is to buy a whole refurbish tv Tuner for the replacement,if u have to have those HDMI inputs for your tv,can't used other inputs to handle ur tv need to functions the tv the way u wanted.U some mechanical skills,like can take thing aparts and putting it back together.Yes.Try website like Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Jul 25, 2011 | LG 42PG20 42 in. Plasma HDTV
My 32" Lg set now
Go to the menu and check you input setting . Or take the remote push the input button (tv/video)If this does not help then hook that input cable to another tv to check for signal.
Mar 01, 2011 | LG Televison & Video
Hello I received a lg flatron plasma MZ42PZ14 and just wanted to connect the tv cable to the tv, but i can't find any coax on the tv. what can i do?
This kind of tv u must have cable or satalite tvs pay broadcasting signal cable,so u have a box .Tv have HDMI ports or RCA AV component cable input?The incomming broadcating tv signal go to the cable or satalite boxes.Than u use a HDMI cable or RCA AV component cable go through those boxes than to ur tv HDMI input ports or RCA AV component cable input holes.
Jan 22, 2011 | LG MZ-42PZ14 42 in. Plasma Television
Power supply not work samsung plasma tvmodel
www.scribd.com/doc/.../LG-TV-Plasma-Training-Manual
www.scribd.com/.../LG-Training-Manual-TV-Plasma-60-INCH-PDP
http://www.schematicsforfree.com/archive/file/Sony/Video/Sony%20Plasma%20Training-1.pdf
please use these service and training manual, to troubleshoot and service.
May 19, 2010 | Televison & Video
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Cant afford cable box need help
depending on if the dvd player has functions such as video input , but not likely
if the plasma only has certain video inputs and not the cable input you could use the vcr to get the signal
Oct 09, 2008 | Akai PDP4225M 42 in. Plasma Television
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
