If you get the Engine Panic error message, you need to turn the power switch off and then back on again. If that doesn't fix the error, contact a service representative to help resolve the problem.
SOURCE: kyocera fs 1016 engine panic
Disassemble and look the fan side of the fuser, there you will see that the wires
pass through a **** that is more of a cover remove it and there's the
can on that side is where will the current regulator and the
high card that connects to the source card,
Well it
happened to me this issue, I found the card and it was high toner
developing unit that was discarding, in addition to the seal of the
doctor blade was worn out, another issue I found was current leakage,
what I did was make the can land top with more pressure to the high
card, in addition to not fall toner worn by the seal tape to tape the
holes in the chassis, after that I have not been flawed
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
LSU cleaning motor error
When the LSU cleaning motor
is driven, an error signal is
detected continuously for 1 s.
Defective connector
cable or poor
contact in the connector.
Reinsert the connector. Also check for continuity
of the connector cable. If none, replace
the cable.
Scanner carriage error
The home position is not correct when the power is turned on, at the end of a reading process of the table and document processor.
