Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
External Hard Drive not being recognized (A little different)
I've gone around and read some of the solutions but I don't think they apply to my case. I probably don't know the difference either way but heres pretty much what happened.
About a month ago, my hard drive was fine. Had it for a few years now and it's performed flawlessly. Ever since I took it on a trip with me and plugged it into a different computer (it never had a problem in other computers) it would blink, and take much longer than before for the drive to be recognized. Ever since I got home its been doing that, blinking and taking much longer to be recognized.
When I got on my computer this morning, it was blinking but taking an EXTREMELY long time to load. After unplugging/replugging in the cables and turning it on/off, I decided to restart. As my computer was shutting down I noticed it stopped blinking so I canceled the shut down. Now when I turn it on, the light stays blue but that's it. It's not recognized, it doesn't blink, it doesn't do anything.
I've tried switching the USB cables but it doesn't make a difference. I don't have any other matching power chords to test it, but I don't think that's the problem. I would like to open it and install it directly into my computer via IDE but it's quite difficult to open and shows no immediate ways of opening the case, other than popping it open with brute strength which I'm afraid of damaging any of the internal components by doing so.
  • Extacide Sep 23, 2008
    Argh, couldn't find a function any where to edit a question, so I'll just update it with a comment:
    I've finally managed to get it open. For future reference, open it from the back end where the ports are and not the front. If you open it from the front, you might rip out the LED wires from the front LED. Also, it doesn't snap back on, so yeah~
    I hooked it up to my computer as an internal hard drive, and all it's doing is making a clicking noise before going completely silent. My computer doesn't recognize it as a drive. There is a LOT of important information on there that I failed to back up, and losing it would be horrendous. @_@
  • Extacide Dec 27, 2008
    Thanks for the response!
    I was thinking of just doing just that; buying a new harddrive and replacing whatever is broken, or even removing the platters and putting them into the new harddrive. I guess I'd have more questions then:
    If I can simply put the platters into a new drive, is there any specific kind of compatibility issues I should be aware of, or will any harddrive do.
    Also, as for the data recovery. I got a few quotes that ranged from $400 to $600, but my friend said he knows of places that do it much cheaper. Would you be able to confirm and maybe even recommend where I could ship my harddrive to for a quick and cheap data recovery? I want to save money, but the information on the drive is too precious so I may have to resort to it in the end if I can't fix it myself.
    Also for the record, the click sound it makes is a VERY quiet click that clicks every second and a half.
IOMagic has become notorious for some faulty power supplies in the past. If you've got it on your internal bus now and it's still not working, you're in trouble.
It all depends on the noise it's making. I've got an IOMagic 500G that's ticking away like crazy right now. The platter doesn't spin up though. Put your ear to it when you start your computer to see. If I give mine a quick twist I can get put a little inertia into the platters to help the motor overcome the standing friction and then it works until it powers down and stops spinning.
I've had others fail where the arm, with the read/write head on it, goes out to read the platter and the alignment is off, whether it's by impact or age or whatever, and you hear the arm go out, then there's a tick tick tick and then it parks itself and tries again. This is a really bad sign.
Some people have suggested freezing the drive. The cold changes the alignment for a while and you can maybe get it to read those first few sectors and then it's relatively fine for a while.
Some people have suggested buying an identical drive, exact same serial, to replace the external pcb incase the electronics have fried. This is not so likely but worth a shot, especially if you've got an old drive and a replacement is cheap.
There are a few other things but it gets more severe from here.
Advice: anything above that you do to it will void the waranty and will likely speed up decline of the drive.
If you get it to spin up and read, start imaging the drive to another drive right away and cross your fingers. It may never read again after that. Hope that you get it all before it kicks the bucket.
Make sure you image to another drive that is bigger. I've had an image of a 500G drive take over 3 days to complete only to fail because it didn't have enough room to close the control file. I was short a couple of kb on the destination drive. I was away when the fail happened and the drive powered itself down. I could never get it to read again. I was lucky enough to manually edit the control file and got almost all of my data back.
If your data is irreplaceable, and means the world to you, then your only real option is to take it to a data recovery company. They will remove the platters in a clean room and make an image to work from if they can't get it to work otherwise. This is of course very expensive. No one likes to hear it though. If you start messing with it first you may severely limit their chances for successful recovery.
If you simply can't afford it then try everything you can.
I've had drives not read for months and then I throw them in an enclosure just for kicks and the temp is just right or something, you never know, and they read long enough to get the info off.
Good luck.
"data doesn't exist unless it's in 3 different places", words to compute by.
Posted on Nov 22, 2008
How to fix my external hard drive not detected?
If a replacement usb adapter doesn't fix it, your hard drive has failed and usually not recoverable.
Jul 11, 2017 | The Computers & Internet
How can I attach this as a slave drive to my desktop pc as it is not being read by my pc?
You don't need to attach it as a slave drive. Just plug it in to a usb slot on the pc. If you've tried formatting it and been unsuccessful and If your pc isn't recognizing it and it has Windows XP or later installed then the drive is dead.
Jun 29, 2012 | Western Digital 250GB MyBook External USB...
Have several Simpletech 250 GB drives. All are consistently recognized by my Lenovo laptop but one. That one problem drive will rarely get recognized about 1 in 200 tries on my Lenovo laptop. The problem...
You don't say how all these devices are connected at any one moment in time, whether you use a USB hub to plug multiple devices in simultaneously or whether your otherwise detailed and very good description of the background to the fault applies even when nothing else but the problematic drive is plugged into the laptop, or whether you use the same or different USB cables with the different drives and the different computers. It's worth eliminating a USB Port fault or a USB Hub overload or a USB cable fault as the potential causes of the problem, if you have not already done so.
USB is a relatively limited technology in Data Transfer Speed terms and is susceptible to Data bottleneck problems leading to read/write errors in external drives.
The Simple Tech case contains a controller card. The Simple Tech controller card may be faulty or failing due to an accumulation of such read/write errors and is probably not communicating well with the Lenovo's Operating System. Because of Temporary Files and Error Reports created whenever a read/write errors occur, The Lenovo 'remembers' the problematic drives electronic signature from the last connection and also remembers its response and therefore defaults back to the same reaction most times you connect the drive in question. The drive has no 'history' with the Dell, so no problems arise when it's connected there. The other drives might be mechanically identical, but the internal controller board of each has a different electronic signature.
The controller card has a chip on it that contains information in it that identifies what type of device it is to your operating system and then invites the Drivers for the device to start intermediating between the device and the operating system. Some error in the interface between that chip and the Lenovo is causing your problem.
It is purposeless to continue using the problematic SimpleTech Enclosure with your Lenovo Laptop. You have already alighted on the best, simplest and most practical solution -re-house the problematic drive in a good quality, well ventilated new enclosure. The controller in the Eagle case also has no 'history' with the Lenovo, hence the clean response.
For intellectual curiosity, you could swap the hard drives around in two of the Simple Tech cases to see what happens.
Also there might be a Firmware update for the problematic SimpleTech Case that might flash and overwrite the Controller card main chip. I am unable to check this for you as I would need the Drive's part Number. This is the relevant site:
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most insightful, comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa
Sep 06, 2011 | SimpleTech SimpleDrive 250 GB External USB...
I've had my external hard drive My Book Essential for a while now and had no problems with it until now. I would usually plug it in and the pop up screens would ask what you would like to do like...
The fact that it displays a '0% used' indicator probably means that somehow the data that you have hitherto stored on your external hard drive has been erased. This might not necessarily be the case, so don't panic yet.
The first thing I would try doing is reinstalling any software that came with your WD My Book. Not many external HDDs require additional software to run properly, but if yours does, then I strongly recommend reinstalling that first. I would then try using Windows Disk Manager to see if your computer is recognizing the G: drive as a hard drive, because I have had to use disk manager when I've added additional internal hard drives to my computer. If neither of these work [or you could not find the CD your My Book came with] I would search around online for driver or software updates available for your device.
One thing that I noticed while typing my suggestion for you is that before you attempting using the back up feature on your My Book, the drive for the My Book was (G:) but after you attempted the back up process the drive is indicated as (H:). I think that what might have happened was that when you attempted backing up the My Book, it was partitioned into a storage section (G:) and a section in which the backup data is stored (H:). If you can find and access it, the (G:) drive is likely to still contain all the data that you previously assigned to it.
If this doesn't help, I apologize, but I sincerely hope that your problem will be resolved.
Aug 24, 2011 | Western Digital My Book Essential 1TB...
My hitachi external hard drive dropped yesterday. There are no cracks gone on outter surface but my external hard drive now doesn`t read. As well as now the different internal sound is hear. But lights are...
Try to open the casing and disconnect the mobile harddisk inside from the connector. Then put it back firmly. Make sure nothing is loosen. If it still does not read, just plug the harddisk to a different enclosure to be able to retrieve the data
Jul 04, 2011 | Computers & Internet
External hard drive shown as portable disk and does not work
i think the hard drive is ageing,
if you are past warranty try to open up the casing and try to see if you can connect the HDD to connect individually else where (like with another casing or Laptop PC) if still not connecting then the problem is with the HDD
else the problem may be with the casing
pls rate if this was any help
Jul 13, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
SimpleTech 80 GB Portable HD Won't Read
It sounds like a problem with the board inside the case,- the actual hard drive is probably OK. Opening the case will void any warranty but there may not be much left anyway. There should be 4 screws in the bottom of the drive,- front 2 may be hidden under a sticker. Try installing the drive in your new case or an empty drive bay inside your computer. I have had external hard drive cases fail before and the actual hard drive was ok.
Jan 23, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
PC stopped reading Cavalry External HardDrive
i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Dec 02, 2007 | Western Digital Caviar WD200BB 20 GB Hard...
Won't recognize my USB
Nov 30, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
PC won't recognize external usb HDD
You may not have installed the HDD correctly in the case... I had the same problem with my Thecus N1050 enclosure, the green power light on the enclosure would come on and the drive would spin up but my PC would not see the HDD!!??... I thought, becuase i could hear the drive spinning that i had it installed correctly but this wasn't the case, when i removed the enclosure again and FIRMLY pushed the HDD into the connector (all the way in) and connected it back up to my PC, it recognised it instantly. Hope this helps!
Jul 25, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
215 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
Mohamed Ismail
Mohamed Ismail
Falling star
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
