Question about RCA RP4803 Clock Radio
Rca rp4803a clock radio
Set time on clock rca rp4803 cd clock radio
SOURCE: Changing time on RCA CD clock radio
UNPLUG!!! Wait 15 seconds. Plug in again, CLOCK will flash 12am.
Press "set" button ONCE.
Press Double Back Arrows |<< to go backward from Midnight
or
Press Double Forward Arrows |>> to go forward from Midnight
(Either press-hold the Double Arrows for quick minute-scroll or repeat-press Double Arrow for a slower minute-by-minute change.)
Posted on Nov 02, 2008
SOURCE: Virgin Pulse model VP-07 CD clock radio
1. To set the clock to leave the unit in standby mode. (Plug in the AC cord to a wall outlet without switching unit on). 2. Press SET button for about five seconds until AM--12:00-- stops flashing. 3. Press down TUNING button to adjust hour, and up TUNING button to adjust minute. 4. Press SET button to confirm time set.
Posted on Oct 07, 2007
SOURCE: complicated GE clock radio/CD player
To set the time:
Hit the SET Wake/Time Button closest to the CD player until the clock face appears in the bottom left hand of the display.
Use the TRACK Rev Search Fwd Arrows to adjust the time.
Rev will decrease by minutes and Fwd will increase by minutes.
Hope this helps.
Posted on Mar 09, 2008
SOURCE: RCA RP5420 clock radio
Bob, My auto-set worked fine. I'd suggest setting the time manually (by sliding the top-rear slider all the way to the right and using the '<<rev' and 'fwd>>' buttons) if you are still having problems.
Posted on Mar 28, 2008
SOURCE: need operating instructions for RCA clock radio Mod. 5430
The instruction manual will not help you, because it doesn't address this problem head on.  You're having this problem because the time changed, and the clock has an automatic setting.    As long as the batteries are in the clock and it's plugged up, it automatically computes the time. I just discovered the solution.  Unplug the clock, take out the batteries and WAIT about an hour.  Plug it back up, and the time will flash, allowing you to change the time.  You do this with the button on the top back which says wake up 1 and wake up 2.  Push that button all the way to the right to the setting that looks like a little clock, then press the forward button on the top of the clock to set the correct time.  Then put your batteries in and you're good to go!  (til the time changes again:)  Good luck!
Posted on Nov 05, 2008
Hello
I've the user manual for your RCA RP 4803 clock radio. But I can't send it to you by this site, as this window does not allow me to upload PDF files by it. If you want to get it, you have to buy one amoung my services published by FiXya. According to FixYa new site, I can't upload any PDF files to customer, without Fixya's permission. Just buy one amoung muy services. You can access my services by typing my nickname "gopakumarg43" in Google search box and click search. Clik on 'gopakumarg43-FixYa" and you can see all my services there, published by Fixya. You can access directly to it, which in turn let you ot get into Fixya site. There is on service provided by me to send manuals for clocks and clock radios. You can select ti and can access me. OK.
Nov 11, 2011 | RCA RP4803 Clock Radio
C.D. keeps skipping.
If you look below there is a concise post for the same problem already. CD problems are universal as are the workarounds. Defective tracks, damaged discs or dirty/defective player. Economics, as he says, prohibits actually repairing most low-end products.
The web is full of information and advice. This one leaves no stone unturned. http://www.repairfaq.org/sam/cdfaq.htm
Oct 17, 2011 | RCA RP4803 Clock Radio
Set alarm clock
goto http://voxrightnow.custhelp.com/app/answers/detail/a_id/12057/~/operating-the-rca-rp4803-clock-radio
or follow instruction
  1. Press the SET button until WAKE 1 / WAKE 2 icon is blinking.
  2. Press REV or FWD to set the wake time. The time decrements or increments will follow by a faster rate when you press and hold either REV or FWD.
  3. After the WAKE time is set, press SET repeatedly until no icon is blinking.
Tips:
  • The unit equips with GRADU- WAKE feature, the alarm tone volume will increase gradually to its maximum in about 30 to 45 seconds.
  • If you set the SLEEP function with low volume level before going to bed, we advise using WAKE mode to wake you up since its volume will automatically increase.
Waking by Selected Source: You may be woken up by WAKE, RADIO or CD.
  1. Select an AM or FM station.
  2. Set wake time (see above directions).
  3. Press WAKE 1 or WAKE 2 to select waking up by WAKE, RADIO or CD. Corresponding indicator will be shown next to the selected setting.
  4. Adjust the volume by turning VOL.
You can select your CD wake track by the following procedures:
  1. Make sure you have inserted a CD.
  2. While holding WAKE UP CD TRACK, press REV or FWD to select your desired CD wake up track.
Mar 18, 2011 | RCA RP4803 Clock Radio
How do you set time on RCA RP5435B
Use the manual in the following link. It's for a similar model, so perhaps they work the same.
http://portablemedia.manualsonline.com/manuals/mfg/rca/rp5430.html
Mar 14, 2011 | RCA RP4803 Clock Radio
I have an older model rca cd clock radio dual alarms. I cannot find my instructions for setting the clocks time. The batteries were dead when the electricity went off. Now the time keeps flashing the time.
For most clocks of the RCA clocks without a clock or time set button, press Set until you see the clock icon. Press the fwd or rev button to change the time. Release the button when you reach the correct time. (AM or PM will be indicated next to the time.)
There are manuals for several RCA cd clock radios available from their site: http://support.rcaaudiovideo.com/select.aspx?u=manual . Check if your specific model is listed in the menus.
I hope this helps.
Feb 03, 2011 | Vacuums
Setting the time on my clock on radio Model # RP3755B
Well, I have an RCA clock radio/CD player and just figured it out. Press the "Time" button and hold it down while pressing the CD "Forward" button. Hope it works for you! Ron
Jul 03, 2008 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Need owner's manual to set time
i can't set the time i need help
Apr 12, 2008 | RCA RP4803 Clock Radio
or
Sep 20, 2007 | RCA Radio Alarm Clock
RCA RP4803 Clock Radio Logo
311 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
