Question about HP DeskJet 6122 InkJet Printer
Printer Problems Dear leroyal, You recently replied to a post I made about faint lines and white horizontal lines on pages that I print. You replied that my ink cartridges may be dried up. Since I wrote you, I have since discovered that the problem only occurs when printing from Microsoft Word. Other documents and web pages print fine, so I don't think the problem is with the ink cartridges. And the test pages, which also print fine, are in black. Any other ideas? Thanks for your help. Terry
  • gillian59 Sep 23, 2008
    Adjusting the print quality helped, but didn't completely solve the problem. Same with using Bold. Aligning the cartridges didn't seem to have any effect and "clean pen" was not an option.
    I don't seem to an application called wordpad on my computer, which is a Mac.
    At least with the adjustments you suggested, things are legible now!
    Thanks!
    Terry
    Genius:
  • 2,120 Answers
Hi Terry,
It's hard to imagine software being the problem, however, I never say never.
Have you tried the BOLD [B] tab in word?
Right click on the printer in control panel, select properties, advanced, and see if there's a contrast adjustment or print quality, select BEST
USUALLY this only works with laser printers, but it might be there.
Open the HP Tool Kit and select ALIGN CARTRIGES, and CLEAN PEN, if it's there.
Click start, run, type in wordpad, press enter, type something and print.
Please let me know. I'm stumped!
Posted on Sep 23, 2008
Black lines
Replace the toner cartridge :-)
Apr 05, 2014 | HP LaserJet 1020 Printer
Two faint white horizontal lines
the white ghost lines are down to the charge wire within the toner cartridge being dirty, the only real way forward is to replace the toner cartridge as access to the charge chorona wire is not possible without ruining the cartridge itself
Jan 09, 2014 | HP LaserJet 1000 Printer
Xerox Phaser 6180N Laser Printer printing a faint but noticable blue line when printing in color - not an intentionalline. The lines are 3
Most likely replacing the cyan print cartridge will clear this right up. The part number is 113R00719 for the standard capacity. Iteminc.com has this in stock and ships same day for $99. Good luck, and thanks for using fixya!
Nov 21, 2011 | Xerox Phaser 6180N Laser Printer
Faint horizontal dark line about 2 1/8 inches down from the top
You can easily fix this yourself, one of the quickest ways to fix it is to print 10 doublesided blank pages and it will clean the inside of the machine for you and the line will vanish.
For further print quality problems on this machine follow these instructions to troubleshoot.
When troubleshooting image quality problems, it is important to understand the situations in which the problem occurs.
Print a copy of the color test pages to determine whether the problem is in one color or more than one color.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Color Test Pages], and then press the [OK] button to print the test pages. If the problem occurs with one color on the test pages, perform the solutions for this problem. If the problem occurs in more than one color on the test pages, restart your search and select a case for the image quality problem occurring through all colors.
Mar 27, 2009 | Xerox Phaser 7400/DXF Laser Printer
HP 1610 printer
It occurred to me when I was reading your post that photo paper has printing and non-printing sides. If the paper is loaded upside down, it's printing on the non-print side, which would result in what you're seeing. It's just a hunch, but you might want to consider it.
HP.com has a web page that will walk you through the process of checking on this and other potential problems.
Checking image quality problems
Hope this helps. Good luck.
Oct 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
Prints Faint green horizontal lines
Go to control panel and printers and faxes and right click on printer icon then hit printing preferences, go to maintenance and do head cleaning cyles and print nozzle check. if it comes out fine trash and reinstall driver
download driver from support.epson.com site after selecting the printer mdel on the lists
Apr 12, 2008 | Office Equipment & Supplies
HP 7110 still won't print in color
Your post "...it prints very faint horizontal lines in color..." is indicative that indeed your color printheads are clogged and would need repetitive deep head cleaning. This is of course would require that you keep on cleaning until such time as the faint color lines have turned to legible print.
Apr 08, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
Feb 20, 2008 | Ricoh Aficio CL2000N Laser Printer
HP DeskJet 6122 InkJet Printer Logo
123 people viewed this question
Seeker5211
Seeker5211
