Question about Refrigerators
Kenmore side-by-side stops cooling
I had a problem a while ago where my fridge/freezer just stopped working. I replaced the start relay module and my problem went away, as so I thought. Now, I have the fridge would stop cooling, I can get it to start again by moving the controls to off then back on again.
I'm close to replacing the fridge, but I wanted to see if this is a common issue with an easy fix. Any help is greatly appreciated...
  • 1 more comment
  • pinoyfixya Sep 22, 2008
    I can't seem to find the part cold control for my fridge (model: 10653502300). I looked it up on sears parts store.
  • pinoyfixya Sep 23, 2008
    I should add that over the weekend I pulled the back panel and found that my coils are frozen. Could this cause problems?
  • pinoyfixya Sep 26, 2008
    I replaced the thermostat and the problem seemed to disappear [for now]. Thanks doc for all your help.
  • 943 Answers
Hi thanks for the question if you turn the controls and then it starts i would replace the cold control if this part fails it will allow the fridge to get cold but not come back on just tapping the control will get it going again replace the cold control thanks the appliance doc
Posted on Sep 22, 2008
  • john gagnon
    john gagnon Sep 23, 2008
    hi the part is also called thermostat it may be listed as that thanks
Kenmore coldspot 106.54563300 is not cooling. First the freezer stopped cooling then the fridge stopped. The fan is still working. Pulled fridge out, compressor was very hot. Is this a relay problem? If...
Not good news, it sounds like a compressor problem. Vacuum clean everthing you can safely get to in order to make it eaiser for the repair guy, (hopefully to save money). How old is the fridge?
Jun 21, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Replacing a relay switch on a Kenmore Side by Side
The start run relay kicks the compressor on. If your compressor is running this is not your problem.
There are a number of things that can cause a fridge not to cool. A bad defrost system.. Check to see if you have ice build up in the freezer, or a lot of frost. Also a bad compressor. The relay switch sits on the compressor at the back of the fridge. If you put a new relay on and it won't start the compressor you have a bad compressor. Most compressors are warrantied through the manufacturer for at least 5 years. So if it's that call the manufacturer for replacement.
Apr 15, 2009 | Kenmore Refrigerators
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
My kenmore refrigerator side by side
All the cooling takes place in the freezer and is blown over to the frig side so the frig side will start to warm up soon. Possible cause is the starting device to the compressor is faulty, compressor motor locked up or cold control faulty and not closing.
Feb 19, 2009 | Kenmore Refrigerators
Kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Relay clicking, not cooling either side
First of all Give me model# and Serial#.
you will most likely have to replace main control board and evaporator fan motor. They have had a service bulletin out on this problem.
Jan 17, 2008 | Hotpoint HSS25GFP Side by Side...
Kenmore 106.53603202 stopped cooling making a clicking sound
The compressor is locked up. The clicking noise is the thermal overload turning the relay off and on. The only solutions you have are installing a hard start capacitor. Ther local appliance parts supplier will have this. Its easy to install I personally have had a 50% success rate with these, but its relatively cheap fix if it works, as the other solution is a new compressor. Good luck.
Jan 05, 2008 | Kenmore 53642 / 53644 Side by Side...
Fridge stopped working suddenly
Sounds like the relay (start device) on the compressor has failed.  This is a very common problem especially for models that are 3-5 yrs old.  I would replace that first.
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
