Question about Canon ImageClass D861 Printer
Replacing the fixing film for the Canon D861
I read your directions for replacing the fixing film on the D880. Will the same steps work to replace it on my D861? Is there anything I need to be aware of before attempting this task? I bought the copier at a salvage store for only $40.00 and have used it a year. I don't want the expense of a service call and opted to attempt the job myself. Thanks in advance for your help.
  • 42 Answers
Same directions, just be careful when applying silicone grease- only use a thin film
and cover entire area that the film rides on. DO NOT damage film!
sorry I could'nt post earlier been busy
Posted on Nov 21, 2008
How do i fix a printer reading system Error E808
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the fixing drive motor.
- Replace the DC controller PCB.
- Replace the power supply PCB.
Feb 07, 2015 | Canon iR 2016i Black and White Copier
Canon imageCLASS D861 - Windows 7 - 64 bit Is there anyway to update the 32 bit printer to the 64 bit OS?
Unfortunetaly, there is no solution for your problem, Canon did not made drivers for 64-bit OS's.
Alterantively
You can try download Windows XP mod for WIndows 7 or any other virtualization software, and try to install drivers on the virtual PC.
This should work for you.
May 09, 2011 | Canon imageCLASS D880 All-In-One Laser...
My xerox machine cannon IR 2020 shows a system error E007. How can I solve it? Please describe step by step.
E007 - Fixing film rotation error
You have to disassemble fuser unit and inspect a fixing film, if damaged - replace.
The official documentation says:
E007 0000 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
Nov 11, 2010 | Canon iR 2022 Printer
ImageClass D880 Copier: printer is double printing...
If you are getting ghost images repeating on the page about 3 -4 inches apart it is probably a failed fixing film. It would require a skilled tech to replace the film if that is all that is wrong. If the damage is more than just the film it may require an entire fuser ***'y. I would expect an hour labor and $75 for a film, or $200 for a fuser ***'y.
May 16, 2010 | Canon ImageClass D880 Copier
Is the fixing film part of the fusing unit or can it be replaced separately
Generally, if the film is worn, so are the other parts in the fuser. I recommend replacing the the entire fuser.
Jan 31, 2010 | Canon ImageClass D880 Copier
I have Windows 7 64 bit and I cannot get my canon image class D861 to work. Microsoft advises to install it on 32 bit - how do I do that with my 64 bit computer?
There is solutions to getting the Canon MF 3111 to work with Windows 7 64bit on this site here: http://www.dragonblogger.com/canon-mf3110-printing-with-windows-7-64-bit/ check the article and comments for help.
Dec 20, 2009 | Canon imageCLASS D880 All-In-One Laser...
Canon ImageClass D861 Need Vista 64 bit drivers
I don't think Vista is supported for this printer and if not doubt that it will be as Microsoft are bringing out a new OS to replace it.
Jul 28, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Error E007 canon IR 2016
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
To clear the error, execute the following in service mode: -
COPIER>FUNCTION>CLEAR>ERR.
to open service mode press star press 2 and 8 key same time then press star again.
Is there a fault in the fixing film edge rotation detection mechanism?
YES: Replace the fixing film unit.
Mar 05, 2009 | Canon CLC 1140 Copier
My copier says: E000!!! help please.
Unplugging it for 10 minutes did not work. Using the "Additional Functions", Printer Reset solution worked like a charm. Thanks for the post!
Oct 18, 2006 | Canon imageCLASS D880 All-In-One Laser...
Canon ImageClass D861 Printer Logo
111 people viewed this question
old marine
old marine
