Question about Philips 55P8341 55" Rear Projection Television
Tv menu ok for some reason the picture is fine on the tv but the menu is half gone. its sitting towards the bottom of the screen and i cant see what menu setting i'm on. please help dave
  • Anonymous Sep 29, 2008
    I cannot see the whole menu either. It's half-showing on the bottom.
I am having the same issue! Ugh!
Posted on Sep 29, 2008
How do we get the picture back full screen when it will not show the menu because it is only showing the lower half of the screen for some reason
HELLO.
Sounds like one of the buffer boards has gone.
BEFORE YOU TAKE MY ADVICE PLEASE BE AWARE VERY HIGH VOLTAGE INSIDE, IN SOME SETS 2,000 VOLTS DC.
you will need to turn set off for 2 hours before any work is carried out.
as you look at the back on the bottom are 2 or 3 sets of long thin boards, one of them is gone.
either change one at a time or the whole lot.
hope this helps.
Panasonic TH 46PZ80B Half picture with distortion Diagnosis and Repair
Jun 21, 2014 | Maxent MX-42VM10 42 in. HD-Ready Plasma...
A black rectangle appears in the bottom half of the screen. The rest of the picture is fine, the sound is fine. The box goes away if i press the menu button - but it comes back again. What is wrong?
Do you have a cable/satellite box connected to this tv?
Try this first it sounds like you have the closed caption turned on by accident.
On the remote press the MENU button.
Use the navigation keys to move the selector to CC and press OK.
This should bring up the Closed Caption sub menu.
Ensure that the closed caption is set to OFF
Thanks,
Robert
Feb 26, 2011 | Vizio M220VA 22 in. LCD HDTV
Half my screen is soild white the other half is perfect
one of the ribbon cables connecting lcd control board an lcd panel is not sitting properly or connector is not locked.
May 09, 2009 | Sharp LC52D65U 52 in. LCD TV
TV turned off itself
Can you still turn it on?
If so, does it stay on with sound?
If the sound is ok and the picture is blue (even when changing channels, inputs, etc.) the lamp may have gone out.
Can you see the TV menu when you press the menu button on the remote or TV?
Jan 07, 2009 | Sony KP-51HW40 51" Rear Projection...
Auto sensor finding wrong inputs, cant find good component signal
as any new technology TV as yours. your tv has a microcomputer (kind of mother board) that is not detecting your video inputs or any information to control. The initial set up cannot finish and there it go the answer: you have a blue screen or green with the bars (of course this is another area but still related with the control of video that it is another funtion af the main board). So the outside of the tv is ok now because you made many actions directed to troubleshoot conections, and there are fine, but the problem isn't there this problem is at the board level of the tv. technician is needed.
Jan 04, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
Fault on TV
something fried .. sounds like the vertical has gone ,
call a tech.
Mar 07, 2008 | Televison & Video
JVC AV 32120
Sounds like your "CC" (closed captioning) is turned on and it is set to text mode.Go into the menu and turn the closed captioning "off". The default v-chip unlock code is "0000"
Sep 27, 2007 | JVC AV-32120 32" TV
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Philips 55P8341 55" Rear Projection Television Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
