Question about Kenmore Elite 45986 Front Load Washer
Water on the floor
When running a load we get water comming out from the bottom front of the washer. It still runs the load but we are getting between 1 and two gallons out on the floor. What should I check.
I had this problem twice and both times it was the front seal on the door. Those things are $70-$80 or more.
Posted on Sep 23, 2008
It's probably the front seal (boot)
  • 943 Answers
Hi thanks for the question i would remove the front panel 2 screws on each side at bottom that's where the water pump is located you could have a pump problem thanks the appliance doc
Posted on Sep 22, 2008
Water runs out of bottom of drum through machine onto floor
The first thing to check is the bellows, also called the front seal. Look for any tears, if any found, that would be your problem. If not, then the next thing is to take the top off the machine by removing the screws in the back of the upper part of the machine and checking the lines that run from the water valve to the dispenser.
May 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Water leak coming from under my washer wirlpool duet. what would be causing that?
you can remove the bottom panel in front on this unit... the screws are near the floor then that bottom piece can be pulled away... there is a clean out next to the pump assembly run some water and see where water is coming from most likely a hose or pump assemble is leaking ..check all hoses like i said run unit and you should be able to use a flashlight and find the culprit water leak...
good luck to you
Jan 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Won't run
yes at the bottom of washer remove panel shop vac water pump
Feb 01, 2010 | Samsung WF203ANW Front Load Washer
Whirlpool Front load washer - Water leaking
I would check to see if you have a hole or crack in the rubber boot inside the door. Open the door and seperate the fold in the rubber boot and check for a leak. If something sharp was left in someones pocket it will get stuck in this part of the bood.
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
About 1 minute into the cycle water starts running out from underneath of the washer. Checked all the hoses that are connected to the back and none are leaking
this is either the front seal that goes from the outer tub to the front of the washer or a hole in the outer tub itself or one of the hoses underneath the seal and the hoses are easiest to check you can take a cup of water and slowly pour it into the front seal. take care not to overfill it to where it spills into the tub and see if you are getting water on your floor from that. the hoses tip the washer up onto its back and look at them from the bottom for any cracking etc. the tub itself can only rust out on some of the neptune models or on others is plastic and can get punctured. just have to look for damage with a light and a mirror.
May 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Water Leaking on floor.
probably the water dispenser valve.
Apr 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
55 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
