Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Dark wiew Hi ! I`m having a Nikon D40 since last week .. and today I want it to take a photo but it has a really dark wiew ! I don`t know why but I`m really desperate ! X( And the flash works just fine ! I`ve uploaded a photo to see it , maybe it helps ! [URL=http://img90.imageshack.us/my.php?image=dsc0009nu5.jpg][IMG]http://img90.imageshack.us/img90/4043/dsc0009nu5.th.jpg[/IMG][/URL] Thank you very much !
Lens is bad and being returned to seller.
Posted on Nov 06, 2008
    Problem Solver:
  • 9 Answers
Is see your problem here.
EXPLANATION.
You are shooting with A mode. That is Aperture priority. In the properties that show u use ISO 200, f5.6 and 1/60. ISO 200 for indoor shot was way to low for indoor shooting without external flash. even your flash doest fire at all. See properties > flash mode. F5.6 will produce dark picture. Use the smallest aperture you can. I believe it can go down until f3.5.
SOLUTION.
You cant simply hope you will take picture under that setting. Use maximum ISO accepted, I beleive that the D40 can go untill 1600 but at 800 it has produce noise. Set your camera to M mode, shutter to 1/60 (under this your image will blur. I think without flash help this also will blur. hehe) and aperture to F 3.5. Set your internal flash to i-TTL mode.
CONCLUSION.
You must understand that without external flash, you cant simply get well lighted picture indoor. Plus d40 doesnt have VR function. It is advice you buy SB600 for a good companion.
Dont compare a DSLR with Compact. Why compact can take clear picture with its internal flash?? the answer is the sensor size. DSLR use larger sensor rather than compact. These diffrence will appear if you enlarge the picture. Try google for explanation.
hope these help.
duku
Posted on Nov 05, 2008
  • 34 Answers
Is it set to auto? if not i suggest you check the aperture and shutter speed setting :)
Posted on Oct 10, 2008
I have a Nokon D40 DSLR and a Vivatar Zoom Thyristor 3500 flash that I want to fire off camera to capture high speed photos.I would have the D40 in dark room with shutter in bulb setting. any Ideas
You can either use a PC cord to connect the flash and camera, or you can use a remote trigger to fire the flash cordlessly. Your local camera store should be able to provide options for both.
Jan 25, 2017 | Nikon D40 Digital Camera
Today, my Nikon d40 was showing an error message "press shutter button to release" and was taking very dark photos. Now, the error message is gone, but all photos are still very dark, even with...
Hi,1) Your camera has damage to the aperture control mechanism.
2) If you look in the viewfinder the image darkened, mayhave bent the aperture control lever.
In one must turn for service.
In two carefully can solve
You can also check whether the mechanism malfunctions diaphragm aperture setting to full and see that this does not close completely,pressing the shutter release button.
Best regards
Feb 21, 2011 | Cameras
Every time i take a photo with no Nikon D40 i end up with a blurred dark spot towards the cener of the view finder? what can this be?
Do you only see the spot in the viewfinder or does it appear on the photos? Could be dust on either the sensor or the focusing screen.
Jun 28, 2010 | Nikon D40x Digital Camera
Nikon D40 is taking Dark Pictures. Flash is
kindly see the aparture and speed of xpouser and the iso also if the iso is 100 change the iso to 400 or 800 or u can select he programme option for the best xpousers
Nov 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40x
It sounds like your flash capacitor isn't fully charged up and your taking a photo and there isn't enough power charged up, so your photos turn out too dark. Take a photo, wait for a minute or til you see the flash icon inside the viewfinder lit up and then try taking another photo.
Jan 01, 2009 | Nikon D40x Digital Camera
My Nikon d40 is all of a sudden taking dark pictures
Silvanus is correct - I have a D200 and often by accident adjust the exposure bias dial when taking the camera out of my backpack resulting in dark shots. I bet this is your problem.
Dec 28, 2008 | Nikon D200 Digital Camera with 18-200mm...
Frustrated female with a stupid camera
hi ,
i am a d40 user myself and i dont have anything but praises for the little guy. check out this link from nikon guru kenrockwell . i think his userguide is even better than the nikon manual itself :)
http://www.kenrockwell.com/nikon/d40/users-guide/index.htm
Oct 01, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
DROPPED NIKON d40, now my pictures are all dark
First u have to reset the camera,go through the menu and select reset and yes. the camera will take default settings.Try now.
Reset the camera opening the connector cover.
You try with a different compatible lens .If works we have to change the lens.
Remove the battery and get fully charged .Operate all switches for some clicks. then put the battery and try.
Then u have to consult a mechanic.
Apr 27, 2008 | Nikon D40x Digital Camera
Nikon D40 (very dark photographs)
If lens has aperture ring make sure its set to highest aperture (f22 etc). With nikon CPU lenses, all exposure metering is done inside lens, sounds like lens still has problems. Try another lens to test camera body, camera shop should be willing to help with this.
Apr 11, 2008 | Nikon D40x Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
162 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
