Question about Canon imageCLASS D760 All-In-One Laser Printer
Won't copy document through feeder.
I have a Canon D760 Laser printer/copier. When I tried to copy through the feeder or inside with the cover close, it won't copy. But I can manually copy a document as long as the lid is up. What could be wrong? Use the machine mostly as a copier. thanks
  • 628 Answers
When you say it won't copy, do you mean that the paper won't move in the feeder or that no copies come out? Do you get any error messages? Try using alcohol on a swab or lint free cloth and clean the feed rollers in the feeder. They sometimes get paper dust on them and they can't pick up the paper. Also make sure that any paper sensors that detect when paper is in the feeder are intact. Occasionally they get stuck or broken. Hope this works.
Posted on Oct 26, 2008
Everytime I copy from the adf top feeder, I get a black line running down the copy. I've cleaned, reset, etc., and I sitll get the black line every time. Help!!!???
CClean The MX882 ADF (Automatic Document Feeder)
Be sure to turn off the power and unplug the power cord before cleaning the machine.
  • The power cannot be turned off while the machine is sending or receiving a fax, or when the received fax or unsent fax are stored in the machine's memory. Make sure if the machine completed sending or receiving all the faxes before disconnecting the power cord.
  • The machine cannot send or receive faxes when the power is turned off.
  • If you unplug the power cord, all the faxes stored in the machine's memory will be deleted.
    Print the necessary faxes or save them to the memory card/USB flash drive before unplugging the power cord.
  1. Open the Document Tray.
  2. Open the Document Feeder Cover.
  3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Document Feeder Cover (A).
  4. After wiping, close the Document Feeder Cover by pushing it until it clicks into place.
  5. Close the Document Tray. speed printer service
    http://www.smoothprinterservice.com/
Dec 18, 2012 | Canon MX882 All-In-One InkJet Printer
Where is the platen located
The platen is the part that covers the large original glass. That is why this glass is sometimes called the "platen glass". More commonly the glass is called the original glass because that is where you lay the original to be copied if you are not using the feeder.
Thank You for using Fixya.
Jan 10, 2011 | Canon imageCLASS D760 All-In-One Laser...
Black smudge mark down 2 inches of right side of copy?
Do you see the same smudge mark if you lay the original on the platen rather than using the document feeder? If it only shows when using the document feeder, clean the scanning glass for the document feeder. It's the small glass to the left of the main glass with the cover open. Use a damp cloth and clean off any dirt or white-out.
Nov 04, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Canon D760
You have one off possibly 2 problems.
1. The toner cartridge is defective. Try another and see if the problem goes away.
2. The fuser roller is defective. It has a teflon coating and after a while it either gets encrusted with toner and transfers ghost images or the image doesn't fuse properly.
I would try the first alternative. Let me know if it works for you.
Joe
Oct 26, 2008 | Canon imageCLASS D760 All-In-One Laser...
Cannon Printer
The ADF is the Automatic Document feeder through which you feed the paper in on top of the printer. Usually the cover swivle/opens up, and you can check if there is paper debris in the rollers. Clean the rollers with cotton pad and some alcohol.
Sep 27, 2008 | Canon imageCLASS D760 All-In-One Laser...
Check Document
Look at the sensor arms on the feeder cover...open feeder,and take it off from the sides..there are little wings that pop out of socket, and look at the black toggle arms... one most likely is dislodged...make sure they all toggle freely...ckeck the one towards the bottom first...if you have to , take screws out and pull cover apart to re-insert toggle arms....
Aug 28, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Hp officejet 7310
better u disconect ur document feeder wire connection. and than try that.
Aug 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Canon imageCLASS D760 All-In-One Laser Printer Logo
199 people viewed this question
old marine
old marine
