Question about LG Flatron L1750S 17" LCD Monitor
LG Flatron L1750S LCD won't display anything...
The monitor shows power and if I restart it will blink for a split second and goes completely black. I have another monitor hooked up right now and it is working fine so it is not my video card. I have to shut down from the tower because I can't see the screen, but even restarting doesn't seem to do the trick. Ready to trash it unless someone has any suggestions! Thanks...
  • 4 more comments
  • Anonymous Oct 12, 2008
    Same problem... exactly. I had a Sony monitor for 10 years and it was still kicking. and this for 1 and broken.
  • Anonymous Oct 16, 2008
    Exact same problem - not sure if it's worth fixing or if I should just buy a new moniter. If I do, it WONT be an LG.
  • larholthaus Oct 24, 2008
    Exactly the same- just stopped staying on all of the sudden and can't keep the picture long enough to even turn off.
  • peggy51 Oct 28, 2008
    Same problem, however, the monitor works fine when hooked to my laptop - just not to the hard drive. Does this mean it is not the monitor's fault? ANy suggestions on what could cause this with the hard drive?
  • petag Oct 28, 2008
    DUEL .... Flatron- L1717S ... SCREENS
    Same problem here with the screen NOT lighting.
    I have two L1717S screens side by side, one comes on as always the second on will flash on start up but then go blank. The power light is on & the other screen is fine.
    I will sit here for simply ages pressing the power button and each time the screen will flash on for just a split second. Then after giving up in frustration I leave the screen on and just try to work with the remaining screen - about an hour or more later I will try the power switch again and it works fine for the rest of the day.
    Then the same thing happens all over again next time I switch on the computer.
  • Anonymous Oct 31, 2008
  • 3 Answers
Replace faulty electrolytics. Look foe swolen ones on the circuit board.
Posted on Nov 19, 2008
    Brigadier General:
  • 6,966 Answers
To your concern, a couple of suggestions:
  • if you could try again a reputable electronics service center/shop, pls mention for them to look at the CCF (cold cathode florescent) lamps, the inverter and/or the main board;
  • the blinking light is significant, it could indicate loss of video signal or internal protection kicking in;
  • possibly heat related, check for any of the capacitors bulging or leaking.
If they would reference a service manual or a schematic diagram, pls relay that it is chassis CL-82 for an LG L1750S. Foremost to check would be for the presence of both the 12 and 5 volts,.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 27, 2008
My lg flatron l1753s shows some visual disturbnce like somthing flowing and in few moments shows completely black screen after that normal so......plz tell me what to do to fix it?
It could be the domestic maintenance problem keep your monitor away from moisture and other physical damage it will make your monitor perfect as new working...
Dec 09, 2010 | LG Flatron L1750S 17" LCD Monitor
Flatron L1750S (Silver, Black) 17" LCD Monitor: Out Of Range - what does that mean...
Your PC video resolution is too high for this monitor to display, you need to set your PC video reslotion to the native resolution of this monitor, which is 1280 x 1024 @60Hz.
May 17, 2010 | LG Flatron L1750S 17" LCD Monitor
My LG Flatron L1750S when powered on blinks and then goes out. I have switched over to two other machines (pc's) and the problem follows. Please help me I can afford to buy another monitor right now....
melrosebanjo, Your monitor will need to have some work done on it's "switch-mode-power-supply" and /or "INVERTER" circuit. After you view some vids at YOUTUBE that deal with replacing bad electrolytic filter capacitors and detecting poor quality intermittant solder joints. Search for vids of "LCD monitor repair" "LCD monitor disassembly" !! Learn what are the major causes of LCD BLACK screen problems. Learn the difference between BLACK AND BLANK screens. Read some of my other posts in my profile. then repost with additional comment here on fixya. also visit and FYI Good luck 12fixlouie
Dec 12, 2009 | LG Flatron L1750S 17" LCD Monitor
LG monitor turns on for a split second and then goes black
Sorry to be the bearer of bad news but you called it, the monitor needs to be replaced.Now all we have to do is set the actual time of death...only kidding. Take care, Dana
Sep 13, 2009 | LG Flatron L1750S 17" LCD Monitor
Why does my LG flatron 1953T LCD monitor (19') goes white
Because the fuse on scaler PCB is blown. Open the monitor, open metal cover, disconnect all cables coming between display and boards, take the chassis off the display.
On back side of display you will see metal cover, mounted with tiny screws, take them off. Unscrew the board also and carefully tilt it up. Observe tiny chip fuse (referenced F1 or FU1 or something with "F") somewhere nearby the connector, ring it, replace it with solder drop.
Take everything back together.
Sep 11, 2009 | LG Flatron L1750S 17" LCD Monitor
Screen flashes only for a split-second (as a second display for an iMac)
The inverter is faulty.If your Monitor is powered by a mains'kettle' type lead,then it MAY be repairable,provided you can find someone to do it.If you have an external power supply,then the chances are you have a separate inverter,and it is doubtful whetther you can find the fault or a replacement circuit board....which is why we have become a throw away nation !!
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Monitor has power; shows analog for split second; then goes black
Well...It's seems you got a busted backlight inverter. You need to replaced a new one or repaired it...
Oct 10, 2008 | LG Flatron L1750S 17" LCD Monitor
L1750s 17"
This problem is showing when the main PCB of the monitor failed. contact the LG service provider in your area. Here is the link to get the service center info
Dec 31, 2007 | LG Flatron L1750S 17" LCD Monitor
Flatron L1719S
I think your monitor is unstable. Is it showing power saving when you boot your PC? Does it show something when the Windows XP splash appears?
Jun 05, 2007 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L1750S 17" LCD Monitor Logo
429 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
