Question about Dewalt 18 Volt Compact Drill Kit
Dewalt dw959 does not work in reverse
What part do I need to replace in my dewalt 18 volt dw959 drill to make it work in reverse? It works fine going foreward. All other aspects of the drill are fine too!!
Bob
  • Anonymous Mar 13, 2014
    On my 36 volt I have to hold the big battery in tight for the drill to work small battery works fine?
Tirb
Posted on Sep 22, 2008
I have 3 drills, (2)14.4 and (1)18 volt Dewalt. the 14.4 drills starT to smell of burning and then smoke. One of the 14.4 drills seems to be less powerful. The 18 volt hammer drill is stuck in forward...
Well burning and smoke is either a switch or motor. Disconnect the motor and run it with battery voltage and no switch. If it's still slow and smokes it's the motor if not it's the switch. The other one sounds more like the switch but could be the motor. Testing would be the same as the other. On the 18 volt open it up and see if the reversing lever got hung up. It may be that you can line it back up and be ok. More likely it's a bad switch and needs to be replaced.
All these tools have static sensitive switches and need to be worked on at a static free work station.
Hope that helped..
Oct 16, 2011 | Dewalt 18 Volt Compact Drill Kit
My 18 volt dewalt cordless runs well except when I try to remove something with it. Reversing the drill makes my nutdriver bit fall out as it opens the chuck, so all removals have to be done by hand.
I would make sure that the bit is firmly installed in the chuck, you should hear clicking when the bit is tightening, this is the chuck locking itself on the but. and when going in reverse make sure you dont have your hand or have the chuck pressed against an object. If nether of these are the problem then there may be a problem with the chuck itself and should be replaced.
Apr 02, 2011 | Dewalt 18 Volt Compact Drill Kit
Why has my dewalt 18 volt drill gone slow and less powerful? the batteries are fine on other tools
It sounds like the motor is going bad. You could also try to take it apart and clean and relubricate the gears and shafts whith grease.
Mar 15, 2011 | Dewalt 18 Volt Compact Drill Kit
The chuck on my Dewalt 18v hammer drill will not stay tight. it loosens whether I am in forward or reverse
the chuck on my dewalt 18 volts hammer drill will not stay tight it loosenss whether i am in forward or reverse
Oct 14, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How to change brushes in a Dw959
take drill apart down to the brushes replace with new ones ,hold brushes in with clear tape put back together turn drill by hand until tape s gone ,plug in bat . ready to go
Sep 22, 2010 | Dewalt ; 18v 1/2" Compact Drill Driver...
How to replace brushes in dewalt dw959
Simply Google "how to replace 18v dewalt drill brushes"
You will get three youtube videos on how to do it right at the top of the page...
heatman101
Sep 08, 2010 | Dewalt ; 18v 1/2" Compact Drill Driver...
Dewalt de9092 - the reverse not engages regularly
sounds like the switch is bad and needs replaced, You can go to Dewaltservicenet.com and type in your model number to find a replacement switch, If you do it yourself make sure to write the wiring down first, the switch might be polarity sensitive.
Sep 24, 2009 | Dewalt 18 Volt Compact Drill Kit
Cant figure out how to remove brushes
go to Dewaltservicenet.com and in the middle of the page at the bottom type in your model number and it will take you to a page so you can bring up a schematic on this tool. let me know if you need any more help
Jun 10, 2009 | Dewalt 18 Volt Compact Drill Kit
The motor turns but the clutch will not engage
Take the drill out of the hammer drill setting when in reverse.  Using the drill setting with the speed on 1 will give the power to free the bit.  If the clutch will not engage, GENTLY but firmly switch between forward and reverse.  This should work just fine.   I hope this solution brings you success!  Best Regards,  Michael Mittelsdorf
Dec 26, 2008 | Drills
Dewalt 18 Volt Compact Drill Kit Logo
457 people viewed this question
Top Dewalt Drills Experts
Tyler Craig
Tyler Craig
Level 1 Expert
Soulvisitor
Soulvisitor
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
