Question about Kenmore 62602 Electric Dryer
Kenmore 110.96588210 Electric Dryer
The dryer will not stop running , even if its cut off, runs intermitently. When door open, stops running, but lights are on inside dryer.
also can hear timer dial motor running(ticking)
    Genius:
  • 1,122 Answers
You can take the top panel back off and check the start button with omes meter,push button in you should get a reading,let button out no reading ,if it fails the test replace,let me know what you find
Posted on Sep 22, 2008
Dryer keeps cutting off and has to be restarted.
There is normally a switch inside the motor that detects in turning at speed. That keeps the dryer running until it is either stopped, the door is opened, or the cycle is through. I am guessing that the contacts are getting bad on this switch.
Jan 03, 2012 | Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
My Kenmore 90 series electric dryer not running
http://www.washerwizzards.com ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
Dec 23, 2009 | Kenmore 63942 Dryer
Kenmore electric dryer
HI, the door switch is malfunctioning. either the wires are loose or, the switch actuator if faulty. inspect this area thoroughly. replace the door mechanism if found to be faulty.
Jul 21, 2009 | Amana NED7200TW Electric Dryer
My GE Dryer model DWSR483EA1ww will not stop & doesn't dry quick
first thing you should do is check the flow of your vent, a clogged vent can cause all your problems check it outside while the unit is running you should get really good flow compare it to the flow of the dryer with the vent hose off the dryer completly. they should be fairly close or just run it with out the vent hooked up to the vent if you have an electric but not with a gas dryer
Mar 09, 2009 | GE DWSR483EBWW Electric Dryer
Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
Mar 02, 2009 | Kenmore Dryers
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Kenmore 62602 Electric Dryer Logo
270 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
