Question about Whirlpool Calypso GVW9959K Top Load Washer
C1 code cant find model number on machine to validate service waranty
I have a service waranty from Sears, however the model number wore off the lid on my Whirlpool Calypso, where else can the model number be found. I have moved several times and cannot locate the owners manual:?
    Novelist:
    Champion:
  • 261 Answers
Whirlpool can get you into a range with your serial number, from there they need features and color.
Posted on Sep 23, 2008
Replacement lid
Dear Carlie,
Type "Sears Parts Direct" into your search engine, and then provide the make, and model number of your washer, and you should find a lid available.
Sears sells parts for most all of them.
If you wanted more selection, after you get the part number, try Amazon or e-bay for more selection of parts.
God bless your efforts.
May 27, 2016 | Washing Machines
Valid puk code on mysim
Dear:
My dear:
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
But:
Don't try to enter a PUK code without knowing the right one.
You need to call your service provider to get this code.
It can be as many as 8 digits, and it is random. If you enter too many wrong codes,
you can permanently damage the device. So Please You Go to Service office
and Get the Duplicate Sim From Office Oprater Same Your No Problem will Solved
Dec 19, 2012 | Nokia C1 Cell Phone
Forgot security code of nokia c1-00
*#7328748263373738# to reset security code to default.
Default security code is 12345
i hope this helpful
thank you for using fixya
Feb 06, 2011 | Cell Phones
Lid switch doesn't work
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
On most top loads, you can usually find the model number by lifting the lid and looking at the top of the tub. The model number may also be on the label with the serial number, part number etc.
If you find the model number, also go to the Sears site that has on line (PDF version) manuals.
SEARS ANSWER SITE
http://www.managemyhome.com/
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
Also see the following for a more detailed description of how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
May 03, 2010 | Kenmore 24032\24036 Top Load Washer
Maytag top loader washing machine - Water pump assembly diagram please...
i need your model number open door or lid look inside for sticker or tag sometimes under lid inbtween bottom of lid and tub may have to get low to seee it..... if u get it u can go to sears.com go to their parts section and enter your model number they will list or show you the parts breakdowns, part numbers, and prices hope this helps
Feb 03, 2010 | Maytag Washing Machines
How to replace the lid switch for a top load kenmore washing machine model 110.92480200 part#1170635?
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92480200
Look at the top and cabinet section and you should see how the switch mounts.
A concern that I have is that the part number on the Sears site for your washer is
Switch, lid Number:3352630Substitution:285671which isn't the part number that you quote.
Oct 12, 2009 | Kenmore Washing Machines
Need Owners Manual
If you have not done this go to sears parts direct. If I am not mistaken you model number should start with 917. Hope this will help.
Feb 23, 2009 | Heavy Machinery
Terrible noise on spin cycle, stainless drum is loose inside plastic tub, wore the front half of the plastic tub down due to friction. Took washer completely apart, found the spider arms cracked. It...
Just had the same problem 1 month ago. My Whirlpool Duet front load made that terrible noise. 2 of the 3 spider arms were cracked. I hade a new hole tub with the spider arm and the shaft , because it is 10 years limited waranty . But if it is not under waranty it costs about 270$ for that tub you can buy it from many appliance parts web sites on the net. Good luck, huge job to all remove that thing
Dec 03, 2008 | Washing Machines
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Spin Cycle on Wash Machine does not work
The problem is your lid switch. This is a common problem with this model washer, and a very simple & inexpensive problem to fix. Click on the following link for advice on how to replace:
http://www.fixya.com/support/r385198-replacing_lid_switch
You can find a replacment switch at searspartsdirect.com. Just type in your model number and look under the "Cabinet Parts" heading on the next page. I believe thats the heading the part is listed under. Sears has excellent part locator drawings to assist you in identifying the part. Once you have the part number identified, you can do some comparative shopping at other online websites too. Use the part number that Sears provides, however. A new switch usually runs about $25 to $35. In addition, make sure you check the lid strike. This is a small plastic piece on the lid that is used to activate the lid switch through a small slot. If the lid strike is broken off, it will give the same symptoms of a defective lid switch. I hope this information helps you. Please post back if you have any questions.
Aug 04, 2008 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
75 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
