Question about Refrigerators
Flower cooler does not cooling down the tempeture
  • Anonymous Mar 11, 2009
    first there was ice build up by the fans and now it isnt blowing cold air...I just changed the compressor about 6 months ago, I doubt that could be it? any suggestions
  • 1,122 Answers
Remove the bottom grill and clean the condenser coils,if not that i think your thermostat is bad,let me know-mike
Posted on Sep 22, 2008
  • MIKE major Sep 24, 2008
    did you fixya it?mike
I use my True single door cooler for flowers. How do you adjust the fan so I maintain a 90-95% humidity ?
Unless this is specifically designed for this application, the only way to control humidity is to keep the temp fairly high. Part of the cooling process includes removing moisture from the air. In coolers, the fans run 24/7 unless specifically designed otherwise.
Jul 20, 2017 | True Refrigerators
I change thermostat, water pump, housing coolant sensor, but yet when i start driving the tempeture goes up and down and the heat gets kind of cool not all
poor coolant flow water pump? air lock in system? bring to operating temp shut down than open air bleed screws.
Jan 02, 2014 | 1997 Pontiac Sunfire
What turns on the cooling fan on 1999 buick regal?
the tempeture sensor either water tempeture or a/c
Jul 20, 2012 | 1999 Buick Regal
My car is a volkswagen passat diesel .there is oil in the coolant i was first told the head gasket had blowen. i have also been told it could be the oil cooler. the car is not over heating in fact the...
There is a very easy way to check the oil cooler for leaks.
Do this with the engine cool and be prepared to catch some coolant in a pan.
Remove the 2 coolant hoses from the oil cooler and attach them together using a 5/8 inch straight heater hose connector. You are bypassing the oil cooler temporarily. Wipe the oil cooler clean so you can clearly see any leaks develop.
Now run the engine and watch the oil cooler pipes (the ones you just removed the hoses from) carefully. If you begin to see oil seeping from the cooler pipes you've found your problem.
This might take a while to see so be patient and let the car run for at least 15 mins or more.
Don't worry about the cooler being disconnected while the car is running, but I do recommend reconnecting the cooler if you have to drive it even if you find it to be leaking.
If it is found to be leaking, you will need to replace the part and have your coolant flushed out properly to remove as much of the oil as possible from the system. Also change the engine oil at the same time, it is possible that coolant has gotten into the oil although it may not be obvious.
Good luck.
Jan 31, 2010 | 2001 Volkswagen Passat
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
Warm heat not hot
Check antifreeze level, if it is low coolant may not flow through heater core. If coolant level is ok feel the heater hose with engine running at normal operating temp and heat on high, if one hose is much cooler than the other you have a bad heat control valve or a pluged heater core.
Oct 15, 2009 | Pontiac Grand Am Cars & Trucks
I cant seem to fix my Kaze master 4. 5.25'' Bay Mountable 4 channel fan controller. it always beeps and it doesnt stop and i cant change the tempeture for it when ever it beep my computer over heats so...
kaze master is a good cooler, make sure you seated it firmlly and also try to observe it may be a wire is touching your fan and make it slower, hope this help
Sep 23, 2009 | Ultra Computers & Internet
if its maxed you cant just turn it down accordinly to what they tempeture is to cook if its 350dgs use 300 dgs
Feb 22, 2009 | GE JGBS23 Gas Kitchen Range
Beverage/Wine cooler not cooling
call a local refrigeration repair service .
Jan 15, 2018 | Refrigerators
Tempeture gauge
this is one of three posabilitys or it could be the guage or the wirring to the guage
Oct 19, 2008 | 2001 Oldsmobile Silhouette
Refrigerators Logo
171 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
