Question about Zanussi WJS1397W Front Load Washer / Dryer
Water Retention in Fabric Softener Compartment
The Fabric Softener Compartment always has water in it. I'm not sure whether this is normal and I just haven't noticed it or whether there is a blockage somewhere. I've taken the drawer out and cleaned it thoroughly but still it just sits there.
geemarie
  • 876 Answers
SOURCE: Kenmore Elite fabric softener won't drain
Is the dispenser full? It could be that it is a bit clogged. I would try just pouring a little very hot water in for several loads and using dryer softener sheets during this time. Let's see if we can unclog it .
Posted on Aug 22, 2008
  • 641 Answers
SOURCE: the fabric softener doesn't go in...
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Posted on Aug 04, 2007
  • 4 Answers
SOURCE: Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Posted on Dec 12, 2007
SOURCE: Water in Fabric Softener Compartment
As for the softener compartment, powder tends to overflow and block the three drain holes. It needs removing and thoroughly cleaning out, i use cotton buds and lots of hot water.
Posted on May 21, 2008
SOURCE: Fabric softener stays in drawre
We just had a tech come out to fix this problem for us. Essentially, the problem is that the fabric softener builds up and gets clogged. He cleaned out a solid hunk of frabric softener gunk, and suggested that we dilute our fabric softener with water to keep this buildup from happening again.
Posted on Apr 11, 2009
The fabric softener compartment in is full of water. I need to empty this manually prior to each wash . Many, many thanks. Judy
The fabric softener dispenser has to be purged between wash cycles to prevent residue from clogging it. What you are observing is normal operation.
Jun 25, 2016 | Washing Machines
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
Apr 13, 2012 | Whirlpool GHW9400 Front Load Washer
I have an Aqualux 1200 washer/dryer. After the wash cycle the fabric conditioner compartment of the tray is full of water and the fabric conditioner appears not to have been flushed into the machine
If the dispensers are in their proper spot it is normal for some water to be left in the fabric softener dispenser. When you add your softener add water to dilute it as some softeners are very thick and don't dissolve well especially in cold water
Nov 18, 2010 | Electrolux EW1200i Front Load Washer /...
Fabric softener dispenser fills up with clear water after washing cycle is complete. I do not use fabric softener .
Purchase some fabric softener and place it in its normal location at the beginning of the cycle. At the end of the cycle check to see if fabric softener has been dispensed and whether there is water in the cup.
If the fabric softener is gone, but there is water in the fabric softener cup, then your problem may be with the water valve assembly. The water valve assembly (as one complete unit) has a separate solenoid for hot and cold water temperatures, bleach and fabric softener. The fabric softener solenoid on the water valve assembly could be defective (allowing water to fill the fabric softener cup).
Contact an appliance service company.
Feb 17, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Whirlpool Duet Washing Machine
its normal for this to occour, atvery least nothing to worry about, the unit "floods" the compartment to release the fabric softener, and uses a syphoning action to empty chamber, regardles sof usingor not waterenters the chamber, and depending on level determines if it empties or not
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Remove the fabric softener compartment for cleaning
open up and on the left side toward the back you see a little tab push it down pull out the dispencer
Mar 02, 2008 | Bosch WFMC 3200 Front Load Washer
Dec 12, 2007 | Washing Machines
Dec 18, 2006 | Zanussi FS1455W Front Load Washer
Zanussi WJS1397W Front Load Washer / Dryer Logo
51 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
