Hln567w cn110 socket on dmd
I'm looking for the short pigtail that goes to the cn110 socket on the dmd. 3 wires ,1blue,2 wht.Or what order they plug in on cn110 soket.Thanks,
  • richhog123 Sep 23, 2008
    Thanks for responding,the dlp is a samsung HLN567w
If I had the part # I wouldnt be on yhis site ,someone please help.Thank's.
Posted on Sep 24, 2008
    President:
  • 1,952 Answers
Just click tis link ...u wll get where to connected those three wire
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Posted on Sep 23, 2008
  • mohammed marika thambi
    mohammed marika thambi Sep 23, 2008
    see the 2 white wire and one blue wire connection inserted..
    thanks for using fixya
    rate this solution
    Genius:
  • 1,847 Answers
What is the make of this tv that we are talking
Do they make a plug wire for sealed beam head lights to fit a composite head light? don't want to splice my truck is a 2000 c2500 chevy
Yes, you can buy connector plug sockets with short pigtails of the wires. You still have to splice them into your existing wires to the lights. Just cut off your old socket's wires and replace the socket.
Nov 02, 2015 | Spyder Ford F250/350/450 Super Duty 05-07...
I have a 99 accord the alternator plug was cut. Looks like they tried to splic the wires to fit a different plug or something. What wires do I run to each metal piece on the alternator?
The WHT/RED wire from the PCM connects to terminal 4 (FR); the WHT/GRN wire from the PCM connects to terminal 2 (C); The BLK (or WHT) wire from the underhood fuse/relay box connects to terminal T102 (B); the WHT/BLU wire from the gauge assembly connects to terminal 3 (L), and the BLK/YEL wire from the driver's under-dash fuse relay box connects to terminal 1 (IG)
Oct 09, 2014 | Cars & Trucks
Trying to wire a 3 way switch and I have a black wire, a red wire, white wire, and a grounding wire, I'm not sure how to wire the switch and I'm having difficulties determining which wire goes...
ok typicaly the white wire is your nuteral and the red and black are your travelers so at the spot where you are installing the switch there should be either a set of wires either a switch leg or power set either way looking at the new switch you will notice that one of the screws on it are different then the others the two that are the same are where you want the red/and black to go from your set with the blk/red/wht/grnd the other set should be blk/wht/grnd the whites go together and the grounds go toghter and the black wires if more than one need to be tied together and pigtailed so only one is left and if just one blk that goes to the odd color screw hope this isnt to long winded
Jul 25, 2011 | Cooper Wiring Devices Three Way Grounded...
Firing order for a 1991 eagle talon
info and printed diagram available at your local auto parts store
Sep 07, 2010 | 1991 Eagle Talon
How do I wire a leviton 7299 combo switch. I have power to the box from standard 3 wire cable blk and wht with a grn ground. I then have another cable again blk/wht with a grn ground going to a set of...
Ok this is a GFCI switch receptacle combo. You will connect the incoming cable to the incoming terminals on the Recptacle. White goes to Line (silver) terminal Blk goes to Line (brass) terminal. For the light connect the white to the load terminal (silver) Then take a short black wire and connect from the Load (brass) terminal to one of the switch therminals. Connect the remaining outgoing black wire to the other switch terminal (at bottom of switch) connect both green wires to green ground screw. (best to "pigtail" ground wires so only one wire on terminal. This will give lights GFCI protection also good for hanging lights in a bathroom.
Aug 17, 2010 | Leviton R02-7299-0NW Switch And GFCI...
FAINT VERTICAL PIN STRIPES MOVINGS TO FULL AREA OF SCREEN
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 16, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
52in nassau indoor/outdoor fan 129-909 floor model no instr
white definately goes to white. however you configure the red, black and blues will only determine which switch on the wall controls the fan or light. as for the bare copper, the fans typically come from the factory with a green pigtail screwed into the top of the downrod
Aug 17, 2009 | Hampton Bay 24002 Ceiling Fan
About the DLP TV you helped with.
Brandon. Locate CN110 on the DMD its a wire plug. Pin 2 is gorund pin 4 is voltage for the color wheel. When the color wheel is off pin 4 should have 5V on it when power is pressed it should have 7v for the color wheel to start. If the voltages on pin 4 is 5V your DM is ok and Color wheel would be indicated as faulty, But if pin 4 is anything less than 5V its the DM which is faulty.
Jun 22, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung dlp model HL-R5064W about 3 years old im getting greenish white dot lines vertical about every inches to every 6 inches have had one service person in to look at it but said he need it to take it...
Hi..it is the DMD board (digital mirror display) but IF it can be repaired it would cost around $300.00 to repair and $970.00 to replace. I would tighten the screws that hold the mirror to the board first. All four of them. Sometimes if the screws are loose, you will get the vert. lines too.
Mar 26, 2008 | Televison & Video
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
