Question about Faberware FCP280 Coffee Maker
Faberware coffee pot
12 cup perkulator-- It will perk, but after a short time, it starts to perk again, the coffee of course is awful. thanks for your help.
SOURCE: Need measurement guide
We use 'em every sunday at church - 1/2 cup grounds for every 10 cups water. Allowances: finer coffees will use less grounds, and the more you are making, the fewer grounds you need ( or vice versa- the less you are making, you may need to increase grounds a bit, as perk time will be shorter
Posted on Apr 23, 2008
  • 176 Answers
SOURCE: Coffeepots not operating by not getting hot enough
Hi. Sue, Problem is you're buying China pot's. One of 2 things can cause that problem. The Thermostat or the keepwarm element. 9 out of 10 it is the thermo. The parts are not available in the USA. I have a eBay auction site. I have to make the thermo's out of USA ones. They are 8.00 plus 2.00 S/H. My eBay name is ron622c. If you want to stay with Farberware you can buy a used one or if you are lucky a new one. But don't buy a China one, Good luck. Ron
Posted on Jul 26, 2010
  • 176 Answers
SOURCE: Doesn't perk long enough
Hi you have a pot made in China, 1 of 2 things are broken. 1 the thermostat, 2 the keepwarm element. 9 out of 10 times it is the thermo.You can not buy them in the USA. I have a auction on eBay and I cab make the parts out ob USA parts. Mt eBay name is ron622c, you can take a look. Go to Farberware coffee pot parts. Good luck. Ron
  • 176 Answers
SOURCE: Faberware FSU-122 coffee maker does not perk
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers
Posted on Aug 11, 2010
  • 176 Answers
SOURCE: spout drip faberware coffe pot model 55
Hi. Go to repairshack.con for parts. bobbyone
The pot perks but its just hot water when finished
You need a keepwarm element. Go to repairshack.com. Good luck. Ron
Sep 29, 2012 | Faberware 12-55 Cup Coffee Urn
It seems to be perking correctly but stops and then starts to perk again and again, this continued until I unplugged it, and also the light to indicate it was done never came on
Your pot needs a keep warm element. the main element works ( perks and perks) The thermostat works ( it turns the main element on and off.) The pot goes on and off because the water is getting cold The problem is the keep warm element. The reason, your pot perk's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. Thanks and please ask if you need more help. Go to repairshack.com for the part. Ron
Sep 25, 2010 | Faberware 10-22 Cup Coffee Urn
I have a 55 cup Farberware Urn. Pot will perc coffee sometimes & sometimes not. Problem exists since new, & have replaced both thermos. Water gets very hot, but not as Coffee. Sounds like...
Hi. The spring slips onto the stem just under the coffee basket, it holds the stem with pressure so the perked coffee go up the stem onto the spreader, check repairshack.com Ron
Aug 15, 2010 | Faberware 12-55 Cup Coffee Urn
Vintage Sunbeam C50 doesn't heat enough to perk.
Hi. If you have a light on your coffee pot the model # should 122. A 12 cup older pot. I can fix it for you but you should consider the cost. I only charge for thr parts you need. Shipping both ways is about 10.00 , Max on the repair will be 15.00. My email is callahanronals@att.net Good luck. Ron
May 28, 2010 | Faberware FCP280 Coffee Maker
COFFEE IS VERY WEAK,LUKE WARM,
HI. If the urn perked, it is not the main heating element, that leaves the keep warm element the problem. This element should be on all the time the pot is pluged in, you can get it at callahanronald@att.net for 8.00 and 2.00 S/H.Or go to ron622c on eBay Good luck. Ron
Mar 09, 2010 | Faberware 12-55 Cup Coffee Urn
I have a Faberware coffee urn that perks the coffee, but it isn't very hot. What is the problem?
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white ceramic thing about 3-4" on the bottom of the pot.. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers. I have them. callahanronald@att.net Good luck
Feb 09, 2010 | Faberware 12-55 Cup Coffee Urn
Oct 16, 2009 | Faberware FSU122 Coffee Maker
Farberware coffee urns not working
Dear Pastor Jim
It sounds like both pots heating elements went out or are going out and need replaced! You didnt give the model numbers so I cant tell you the parts numbers to order! but if you go to the faberware website with the model numbers I am sure they can help you!
This should be an easy fix if you are the handy man type!
Please rate this response
Jan 23, 2009 | Faberware 12-55 Cup Coffee Urn
Nov 07, 2007 | Faberware 12-55 Cup Coffee Urn
Faberware FCP280 Coffee Maker Logo
37 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
