Question about Asrock P4I45GV R5 Motherboard
Power up When switch on cpu starts for a second , then everything shuts down..at first this was intermittent, now all the time...
  • Anonymous Sep 30, 2008
    Same problem. Pulled the motherboard and found cheap capacitors on board. You will see that some of the capacitors have a domed top. This means that they have overheated and blown, internally. Either desolder the units and replace, or get a new board. The problem is widespread on different makers boards. The capacitors were of a very poor quallity and have a tendancy to overheat.
    don
  • 30 Answers
Check the capacitors on the motherboard. two or three years ago, alot of boards were affected by installation, in chinese factories, of very poor quality capacitors. To check, look at the top of the capacitors around the CPU, or feel them on the top. If they are domed, even slightly, then the capacitor is blown internally. You can replace them with better units or just replace the board.
don
Posted on Sep 30, 2008
  • 38 Answers
Dear Kresten,
it looks like the problem with either your motherboard or SMPS. So, it is advisable to find a repairman in your
area. You can get the repairman in fixya itself.
thanks,
Posted on Sep 26, 2008
2000 volvo s80 electrical shuts off while driving
Your issue is a relay under the hood in that fuse panel regards Chris
Mar 04, 2017 | 2000 Volvo S80
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Toshiba A135-S4527 starts to power up then shuts down.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
When I turn on my computer it runs for a couple of seconds and then stops.
Unplug everything inside the computer, except the motherboard and the front panel power on switch. Power up the computer. If the PS fan continues to run, (power supply doesn't shut down)and the CPU fan runs, then power off the unit and reinstall each device, one at a time, turn the power supply on after each device is installed (and off, before installing the next device).
You can not easily start the power supply if it is not connected to the cpu motherboard.
If the power supply shuts down with only the motherboard attached, then you will need either another power supply, to test the MB, or another MB to test the power supply.
R
Feb 02, 2011 | Acer DPS-420GB (dps420gb) Power Supply
Half red ligh starts blinking then shuts off
Two possibility , first the 1of the heat sinks may have lost it's thermal seal
to the chips ie G.P.U. or C.P.U. this is more common when consoles
are played vertically . Second but less common the G.P.U. temp feed
connection has become intermittent and tripping a thermal shut down.
Remedy's are
Remove heat sinks for G.P.U. and the C.P.U clean off the old heat sink
compound and replace with new ( articsilver 5 ).
If the console still over heats ( two red lights) then the G.P.U C.P.U
will need to be re-flowed back to the board that normally corrects
the problem in 90% of over heating problems.
If you have any questions feel free to ask.
Rob
May 02, 2010 | Microsoft Xbox 360 Console
Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
Apr 24, 2009 | Dell OptiPlex GX620 PC Desktop
Switch on problem with my system
please you first switch turn on
Jan 31, 2009 | ASUS M2N-MX Motherboard
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
Feb 16, 2008 | Acer Aspire™ T180 PC Desktop
Asrock P4I45GV R5 Motherboard Logo
90 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
