Question about Hotpoint TDC32 Electric Dryer
Dryer drying light going off then heater stoppes working
  • stevetinks Sep 23, 2008
    still spins light gose out then the air is cold switch off light come,s on for a little time then gose off
What make and model number?mike
Posted on Sep 23, 2008
    Genius:
  • 1,122 Answers
Need more info,does it spin and work at all?let me know-mike
Posted on Sep 22, 2008
Dryer is not drying i have to go through four or five cycles. you can see the red light going on and off in the back
By 'red light', do you mean the glow of the heater element or gas burner? Is this a dryer with an electronic control panel, or knobs?
This is probably the 'cycling' or 'high limit' thermostat going bad (or a sensor if it's an electronically controlled dryer). When this thermostat goes bad, it turns the heating element off too soon (because of internal physical wear) and the dryer runs at far too low of a temperature to efficiently dry clothes.
The thermostat is fairly cheap and easy to fix.
Go to repairclinic.com to look up your part. They also have how-to videos for some dryers.
Mar 01, 2011 | Dryers
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
My Bosch electric dryer wta3510uc heats but doesnt get hot like other dryers. why is that? it takes over an hour to dry or even more and it use to seem much hotter. clothes are still cool and damp after 40...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Washer starts then stopps a few minutes in and the delicate and fast and dry lights flash,please help
this sounds like a heating circuit failure, two most likely are failed heater
or pressure switch. Heater is access fro bottom of unit after base tray has been removed base tray will have safety flot switch attached to it,
pressure switch located in frame right front inside right hand panel
Apr 19, 2010 | Hotpoint Dishwashers
My roper REX3514 Dryer will only dry on the time cycle.
If you use a lot of dryer sheets, it will build up an oily residue on the sensor strips causing a "false" reading. Light sandpaper and alchohol over the strips should clean them well. Another possibility, is if you have a mixed load, ie..towels, socks, jeans , if a sock or something light keeps hitting the strips, the dryer thinks the whole load is dry (it doesn't know there are different thing in there) Try keeping loads similar when using auto dry.
Mar 14, 2009 | Roper REX3614KW Electric Dryer
Only half of the heating element works
i looked up your model andfound it to need part number 3401338, this is the heater, i cannot see howe only 1/2 of the coil is going to light, its either on and all lights or its gone bad in which case its never gonna glow, its one filament like a lightbulb as long as the filament is good its alll good. too long to dry or extendedd dry times is most likely an issue with a blocked/clogged vent hose
Dec 09, 2008 | Whirlpool Dryers
Wont start
On the side of the heater box is a small black thermal fuse with 2 white wires going to it. If this is open the dryer will not run.Replace it.
Dec 06, 2008 | Maytag PYE2300AY Electric Dryer
My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Mar 23, 2008 | Bosch Classixx WVF 2402 Front Load...
Dryer overheat and stoppping too soon
Yes, dryer sheets can cause a build up on the sensors and the lint filter. Clean the metal contact strips off (just inside the door) with alcohol or windex and use a toothbrush and a little soap to scrub the lint filter. With the build up you don't get proper airflow and it won't dry right. Also, stop using dryer sheets or be sure and clean the cotacts and filter about once a month.
Feb 22, 2008 | LG DLE5977 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
