Question about Lexmark X6570 InkJet Printer
Paper jam X6570 say on led, clear paper jam then press check mark. There is not any paper stuck in printer and it will not clear or do any thing after I press the check button?
  • 5 more comments
  • skyjenx Sep 24, 2008
    I have a wireless lexmark x6570 (barely used) and now it has a paper jam error and there is no paper jam but i have been unable to clear it. please help before i make it a door stop
  • Anonymous Oct 14, 2008
    same issue. paper jam but no paper anywhere. in fact if i force a piece of paper partly in it will spin it through the rollers and spit it out. ???
  • des4859 Oct 15, 2008
    It happened to me after accidentally sucking in a stack of papers. It's had the paper jam error ever since.
  • bpkalmakis Nov 10, 2008
    Same thing. there must be a way to clear it.
  • Donna Price Feb 27, 2009
    I receive an "alleged" Carrier Jam error EVERY TIME I attempt to COPY a "color" copy.
    PRINTING a color copy works fine.
    PRINTING or COPYING a black copy works fine.
    Can anyone spot the logic here?
    And it is NEVER jammed. The Checkmark button immediately shoots out a blank paper. Never even started printing.
    Any takers?
  • dupright423 Apr 29, 2009
    x6570 paper jam message will not clear and there is no paper jam
  • Anonymous Apr 30, 2009
    It pulls a paper down two or so inches, begins printing on nothing, and then says "clear paper jam then press check mark." But the paper isn't even in. Even without any paper in, it does the same thing.
    Problem Solver:
  • 9 Answers
There is an end of form sensor in the paper path that is likely stuck or the rollers cannot turn due to some other Jam. The machine will throw that message if those two mechanisms cannot function. Look for debris in the printer - give it a good shake.
Posted on Oct 10, 2008
Took Woodchux's ideas and went a step further. As a big fan of Office Space, the movie, I decided to go beyond a shake and gave it a few solid hits on the back and the sides and the top. And yes, now it is working again!!!! "I believe you have my stapler" - Milton
Posted on May 01, 2010
Lexmark will replace the printer for that problem
they actually sent a replacement printer, hen you send the broken one back to them
Posted on Feb 07, 2009
My machine has the same problem please help
Posted on Oct 07, 2008
Paper Jam
Hi Matt,
Here's how to:-
  • First turn the printer off and on.This is known to automatically clear paper jams by pushing the stuck paper out.
  • Remove all the papers from the feed trays.
  • Remove the cover from the housing of the printer to gain access into the inside of the printer.
  • Check for the jammed paper inside and gently pull it out.
  • Press on the flashing paper jam button to make the clearing easy.
  • If this doesn't clear the jam,unplug the printer from power and try removing the stuck papers firmly.
  • Plug the printer back and try printing now.
Check out these video tutorials for more on the same.
Hope this helps.Thanks!
Dec 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Ready and alarm lights keep blinking. will not print
Service manual: ready and alarm blinking :
Paper Jam
Clear the paper jam and press the panel button if the printer
does not automatically resume printing.
Misfeed:
Re-install the paper and press the panel button.
Clear the jammed paper inside the printer. Press the panel button
if the printer does not automatically resume printing.
check the sensors:
1) Turn off the printer power switch, open the front cover, and remove the drum unit.
2) Turn on the printer while pressing the control panel button. The Drum LED comes ON.
3) Lightly press the panel button again.
Alarm LED is ON = Front registration sensor is turned ON.
4) Press and release the panel button again.
Drum LED is ON = Paper eject sensor is turned ON.
If sensors are On, paper is being detected, Off- no paper
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 21, 2011 | Brother HL 1240 Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Lexmark x6570 paper continues to have feed problems after clearing jam.
Hi, In the following link are some tips and a good document on how to clear and how to check if there is something blocking the way of the paper and how to properly load the paper to avoid paper jams.
http://bit.ly/bdk0WJ
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
Printer says clear paper jam then press the check button
There is a line of sensors along the paper path, if any of these are obscured by even the smallest scrap of paper you will get the messasge, re check the paper path again it only needs a scrap of paper, if you can spot any of the sensors give them a blow with some compressed air (paper dust build up), last but worth a try unplug for 2 minutes to allow residual power to drain and then try power up and see if the message has cleared
Sep 08, 2009 | Lexmark X6570 InkJet Printer
X6570 paper jam message won't clear even after paper removed
I had the same problem. What i figured out wich said nothing about it in the book was to.
- turn off printer
- Dbl make sure there is no jammed paper
- put at least one sheet in the feeder like normal
-then turn printer back on ,when printer is going through its start up steps it will pull the paper through that you loaded in the printer and should clear the paper jam message.
It took me a day and a half to figure that one out, so some how post a reply if it works for you so i can pat myself on the back.
Thank you -PURNRG
Jul 03, 2009 | Lexmark X6570 InkJet Printer
My Lexmark X6570 shows paper jam I have performed all the normal orfices for paper and it is clear and the check mark will not clear
I called the Manufacturer and they had me make 5 or 6 different tests and concluded it was a hardware problem. They are replacing the unit.
Thank you for the attempt, but I do not believe you should charge if you can't fix it or have the answer.
Nov 15, 2008 | Lexmark Office Equipment & Supplies
Lexmark X6570 printer - Cleared paper jam. No paper scraps visible anywhere in printer. Continue to get error message to clear paper jam and then press the "check" button. Does not reset. ...
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Nov 11, 2008 | Office Equipment & Supplies
Paper LED Blinking
Did you see http://www.fixya.com/support/r310860-lights_indicate
The Paper LED is flashing.
papereroor2.gif Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
Clean drum unit:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Jan 04, 2008 | Brother HL-2040 Laser Printer
Lexmark X6570 InkJet Printer Logo
357 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
