Question about Frigidaire Affinity ATF7000E Front Load Washer
Bleach/Fabric softner dispenser full of water after wash
This is my third Fridgadaire affinity 6700 washer in three weeks. 1st one had a musty mold smell. The 2nd the door squeaked like a 100 year old door and the the spin cycle didn't work. Now on my third which I just had delivered today after the wash is complete there is standing water past the fill lines on the fabric softner/bleach dispenser. Is there a quick fix to this because if not I'm probably gonna just return the set and get my money back and get LG front loaders. Thanks
I cannot help you solve your problem with your Frigidaire, however DO NOT buy an LG washer unless you happen to be intimately involved with an LG employee!!
I purchase a $1200 LG washer 3 years ago. Until this year it worked very well. Then the bearing in the stator motor blew. This, mind you, is *still* under warrantee but I have been unable, even with the dubious help of LG, to get one of their "authorized" repairmen to come to my house and fix it. True, I live in a rural area, but it isn't like I'm hundreds of miles from any of the three repair services they named. Apparently LG doesn't pay them well for warrantee repairs because they all wanted more money and refused the work!
I am going to turn all of the information and communications I have had with LG (by email thank goodness!) to my State's Attorney's Office.
Good luck in getting this repaired.
Posted on Sep 27, 2008
Not picking up fabric softner
the lines are clogged you must remove old ones and replace
Jul 08, 2014 | Frigidaire Affinity ATF7000E Front Load...
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
My Ge Adora washer fabric softner dispenser
You have low water pressure which wont reach the dispenser drawer during rinse cycle. Clean the feed pipe in case there's dirt in the feed gauze located at the back of the machine. The mould on the rubber is dirt in the machinme. A mixture of 1 cap of bleach and 1 small tub of Swarfega mixed with water and put into the drum on an empty wash will stop it geting worse but it cant be removed.
Dec 09, 2009 | GE WSXH208A Front Load Washer
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
Musty Smell
spray motor and gear housing surrounding with insecticide, roaches may be nesting there that gives out the foul odor
May 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a odor problem with my FAV6800 AWW TL and standing water in bleach & fabric softner cups. The problem has gotten so bad that the odor has seeped into our clothes, yuk. The fabric softner cup will...
Hello mab2005,
Take a look at this post regarding removing Fabric Softener dispenser and clean out and see if it helps. The bleach dispenser is a bit more difficult to clean up I did not bother. You can also lift the washer top using this process to make sure the fabric softener and bleach dispenser drain holes are not blocked.
To raise the top of the machine; Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the Service Manual for putty knife insertion point. You might find something in the Use & Care section of the service manual that might help, I have never looked.
You may have mold built up as I and other users have, see the attached Pic. If I were going to replace a tub seal I would clean out this mold during that repair process. This is the process I'm going to try sonn and I will let ya know if it works. Start a quick wash once the water fill sequence starts I would pause the washer. I would then remove the front panel (as I show in the pic) and view the tub while I very carefully over fill with water to slightly above the mold ring. I would then throw a gallon of bleach in start a continue the quick wash to agitate the solution for a few minutes pause the washer and let sit for a while. Then continue the quick wash thru the complete cycle. I would not try this until I give it a try I’ll let ya know how this works outs.
The tangle problem is inherent to the machine design with
the tumbler rotation action to agitate the wash
load. Hope this helps.
Apr 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Jun 13, 2008 | GE WSXH208A Front Load Washer
Bleach and fabric softner containers do not dispense
I have the exact same problem. However the bleach dispenser has ruined colored clothes by dispensing leftover bleach from the previous white wash on colored clothes. i have had many parts replaced to no avail. Maytag has just agreed to buy back the washer for the full purchase price and replace it with a Maytag or Whirlpool product of my choice. I hope I have better kuck this time.
Feb 21, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
228 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
