Question about Refrigerators
Refrigerators not cooling
I have a Frigidaire FRS24BGGB refrigerator and an older Whirlpool refrigerator, both side-by-sides. My power went out as a result of Hurricane Ike and I connected the Fridgidaire to a small 2000W Honda generator. After two days the fridge stopped cooling, although the lights are on inside. I connected the Whirlpool but it also went out after only a few hours. Both seemed to happen after connecting other devices to the generator, so I'm suspecting it's an issue with power fluctuation. The manual doesn't mention anything about a fuse or breaker inside the unit, but could there be something small like this that needs resetting or replacing?
  • Huckle Cat Sep 23, 2008
    Hi Mike,
    You were right, it was just underpowered. After we got power back we plugged in both units to the house current and just waited. After a while they started cooling again. The sticker inside the Frig unit states 11.6 amps, and by my calculations there are over 17 amps on a 2000 watt generator at 115 volts, but adding other appliances must have brought it below the required amperage. Next hurricane we will invest in a bigger generator! Thanks for your help.
    Trish
    sorry, mike -- I changed the rating and hope that fixed it. I initially rated it Helpful because I plugged it in and figured it out at the same time that you responded. I did find it helpful that you informed me of the reason for the outage, and I did greatly appreciate that you responded so quickly. I should have rated it 4 and if that didn't fix your rating, let me know how I can change it so that it does.
    Genius:
  • 1,122 Answers
No reset but the frigs do have overload circuit that will shut compressor down,the frigs. compressors need a certain about of amps to start and to run ,what is the amp rating on your generator?let me know-mike
Posted on Sep 22, 2008
  • MIKE major Sep 23, 2008
    should of been a fixya,thanks anyway-mike
Frigidaire Gallery's refrigerator side stopped cooling
In side by side units, the freezer side actually cools the refrigerator side by a damper door/switch. Contact a professional if you don't find any blockages in the door area, and the temp does not change.
Aug 12, 2012 | Frigidaire FRS23H7CS Side by Side...
Frigidaire ffus2613ls2 light bulb
If the light is still out, check you haven't inadvertently blown a fuse.
Jun 09, 2012 | Frigidaire FRS26H5AS Side by Side...
Frigidaire FRS22ZRF side by side. Freezer works but the Frig isn't cooling. Anyone know what the problem could be?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 02, 2011 | Frigidaire FSC23F7D Side by Side...
I have a frigidaire gallery side by side refrigerator. The freezer side seems to be working but the refrigerator is not cooling
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 13, 2011 | Frigidaire Refrigerators
Refridge. light went out. Bulb is good. Indicator
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a new Frigidaire whirlpool 3 month old . stop cooling and makes a lot of ice
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 28, 2010 | Frigidaire FRS26R4A Side by Side...
Refrigerator not cooling
heatman101
Jul 23, 2010 | Frigidaire FRS26R4A Side by Side...
Power on but not cooling
mostly either compressor or relay is bad. replace relay and see if it works, since that is cheaper part..
Jan 03, 2010 | Frigidaire FRS23KF7AB Side by Side...
Refrigerators Logo
213 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
