No Sound on Insignia TV
In your post, you said that you fixed the lack of sound issue by running through all of the channels. Can you explain this a little better? I can't figure out what you mean and I spent an hour going through the different options on the menu of the TV. I really would appreciate any help you can give.
  • kevinferns Dec 27, 2008
    I have the same problem..................Good picture but no sound ............
    1] TV not muted
    2] TV speaker on
    Am befuddled.
  • 33 Answers
SOURCE: no sound on analog channels
Grab your sharp remote and press MENU, arrow over to SETUP, arrow down to RESET and press enter and follow that prompt to reset the unit. Once that is complete turn the tv off and unplug ONLY the tv for one minute then plug it back in. Then turn the tv on and see if you have channels, if you do, your audio should work on you analog stations, if you have no channels and all you see is a snowy picture do the following press MENU, arrow over to SETUP...arrow down to CH SETUP and press ENTER...you will then be at a screen that says AIR/CABLE, press ENTER, select CABLE or CABLE(STD) if that option is available to you. after then, arrow down to CH SEARCH, press ENTER, then you should be highlighted on ANALOG AND DIGITAL SEARCH...press ENTER and wait for 15-30 minutes ( or until you get a picture back) and make sure you DO NOT press any buttons or turn the tv off and you should be good. good luck 2 u
Posted on Feb 19, 2009
SOURCE: sound but no picture on Philips 42pf9731d/37
I had almost the exact same model. Mine was a 9631D, built on the same architecture I believe. I can say, if you heard a POP noise, before the picture went out...You are most likely looking at your Y-SUSTAIN, and Z-SUSTAIN boards. Don't let this get you down. Look closely for any blown caps. And You can not only replace one board. unless it's the Z. If you only get the Y, without the Z, or vice versa, you can damage the new board, and end up in the beginning scenario.
Hope I helped,
Adam
-X Com Troubleshooting-
Posted on Jan 18, 2009
  • 27 Answers
SOURCE: Insignia IS-LCDTV32 32" Wont let me change channels or go to menu
there is a problwm wit hyour mainboard you can buy one on ebay for about $80 and to remove just take off back panel and unplug about 5 wires and remove 2-3 screws on the left side / the same side that your power ch+/- ect is on. and swap out.
please rate my answer it is much apreceated
Posted on Feb 13, 2009
  • 814 Answers
SOURCE: Insignia 26 inch Flat Panel Internal Speakers Stop working
You need to test the unit on a external sound source, to see if the audio amplifier is working correctly. By checking it on another source you can determine if the sound amplifier system is failing or you have had some problem with you speakers. Once you determine the problem. If it is the speakers, you can replace them with new ones. However if it is the audio amplifier section failing you will have to take it to a service center where they have all the service information to do the repairs.If the unit is still under warranty, have it serviced by Insignia. You can reach their customer support with this telephone number !-877-467-4289. Give them the model number of your television and the problems you are having with it. The should be able to tell you how to have it serviced. You can also check out their website for customer support at www.insignia-products.com. If the unit is out of warranty, you must have someone help, you troubleshoot the problem and try buying parts for the repair. You can call this number for insignia parts. 1-888-237-8289. You can also search the Best Buy website for parts on these units. The website is www.bestbuy.com. Go to the parts search section and put in the brand name of you television and put in the model number. The search engine will bring up a parts list with prices. I hope this information has helped you with your problem. You should also be aware that Best Buy has had a recall of some these model units. Check my tips and hints postings for more information.
Posted on May 22, 2009
dsacco86
  • 1077 Answers
SOURCE: philips 19pfl5422d/27 same sound problem
This should be a piece of cake for you.
The best thing you need is a Service Manual for the TV. Costs about less than $20 over the internet. It will have schematics, diagrams and part number list for the TV. It's the best thing to use for diagnosing the problem on the audio board. It maybe something simple like a conductive adhesive material for a heat-sink that spread to other contacts on the board.
Posted on Jul 31, 2009
I have a 32 inch flat screen TV by Insignia. It's only a year old.only on channel 9 the sound goes on and off.it stays on for a minute and turns off for 2 minutes. .Why is it doing this???????
If this is only happening on channel 9 and no other channels at all.
This would be a channel issue. The TV would have to have the same issues on every channel for it to be a TV issue.
Hope this helps..
Apr 26, 2015 | Televison & Video
Insignia tv sound but no picture
At 8 years age components are wearing out. It sounds like a power supply issue. It is not cost effective to repair.
Mar 26, 2014 | Insignia Televison & Video
INSIGNIA TV WITH ILIVE BAR. 1 SIDE WORKS
Try swapping your cables from the sound-bar to the TV. If the sound still only plays through one channel but the channel has changed from right to left or vice-versa, then you have a bad cable.
If the performance is the same, connect a different device using the same cables to see if it's the sound bar input or the TV output.
Once you know where the problem is (the sound bar, the TV, or the cables) you'll know what unit needs repair or replacement.
It is entirely possible that a solder joint for the sound-bar has come loose. A soldering pen would easilly fix this if it's a bad joint/connection.
Hope this helps!
Dec 25, 2009 | Insignia 200W Stereo Receiver
No Non-Hd sound
In a nutshell, there is no solution to this problem. The new Insignia TVs have a compatibilty issue with certain HDMI connections. The best thing is to return the TV and purchase another brand. I bought the LG w/built-in DVD and everything works great.
Feb 05, 2009 | Insignia LCDTV26 26 in. Television
No Non-Hd sound
Best Buy owns some of the brands it sells. Best Buy currently has five private labels which include Insignia, Dynex, Init, Geek Squad, and Rocketfish. Insignia focuses on electronic equipment, including televisions, monitors, car stereos, home theater systems, and portable video and audio players.
The Best Buy televisions are made with substandard components. They are not produced with the same standard the orginal manufacture items.
With the factor of substandard pieces and flash/firmware glitches; it sound like you have a software problem.
I would contact the manufacture ASAP and have a field tech come by to update your television.
Jan 21, 2009 | Insignia LCDTV26 26 in. Television
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
No Non-Hd sound
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Is-lcdtv32 and Home Theatre
run all of your components through the stereo first and just bring the video out of the home theater
thanks
scott
May 29, 2008 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
167 people viewed this question
Top Televison & Video Experts
