Question about Freezers
Maytag upright freezer model MQU1556AEW
Freezer won't freeze on upper shelves or door shelves,model MQU1556AEW maytag energy star.setting is on igloo.
  • jamie_dudzic Apr 15, 2009
    following an overvoltage situation, my freezer doesn't freeze items in the upper sections or door. i have also noticed that the"door suction" has significantly diminished. any solutions?
I experienced the same problem last week with my freezer. Apparently the change in temperature during defrosting allows the blade locking mechanism to slide on the motor shaft during the spinning operation. The blade pulls itself along the shaft until it comes in contact with the motor mounting bolt. If your freezer just stops getting super cold, but remains cool and you don't hear the fan spinning, remove the inside back panel and check the fan blades for freedom of movement. I almost disposed of the freezer this past week but decided to make one last check of the mechanisms.
Posted on Apr 07, 2009
The fan blade was pushed all the way back and hitting the motor bolt,not allowing it to spin-no air flow-i slide the blade forward 1/4 inch and retested,all shelves and door shelves now freeze.
Posted on Sep 23, 2008
I have the same issue with no fan, found fan "shaft" had become loose inside motor and fan blade pinching wire between fan blade and motor bracket, Needs new motor and fan blade, fan blade is damaged from hitting bracket, I did contact maytag warranty and explained that freezer only worked six months and has been sitting but they had no offer for help,
Posted on Sep 16, 2009
I've had this problem 2 years in a row and had to go the service repair route so am quite unhappy sinking money into an obviously defectively designed product.
Posted on Jun 04, 2010
Hey so we have a front open door freezer FRF 434 it is not freezing ... why could be?
door seal not sealing
compressor not working
could be a start/run capacitor , low gas or a seized compressor
cal a technician for a proper diagnosis and quote
Jul 12, 2016 | Igloo Cooler IGLOO Freezer. 3.6 cu. ft....
Hi I have this maytag upright freezer model # is MQU1556AEW the problem is that at the bottom inside the freezer there is alot of ice i dont know where this water is coming from I clean but that ice every...
We too have this 2005 model and have to remove ice at the bottom each month....solution...buy a new freezer before we lose all contents.Looking at Amana...high ratings and few complaints
Oct 22, 2010 | Maytag 15.6 cu. ft. Upright Freezer...
I don't have an owners manual and want to know where I should set the freezer to avoid unnecessary ice build-up. Also is there a setting for defrost?
Click Here for your user manual=> MQU1556AEW.pdf The settings for defrost should come automatically every 12 hours. You may test the defrost timer that appears to be behind the kick plate at base and front bottom of refrigerator by removing the kick plate first and using a flathead screwdriver turn slowly clockwise until compressor stops. After a few minutes you should be able to hear a crackling noise or sizzle by opening the door and listening. Leave the timer like that for up to 35 minutes and if the freezer does not start on its own the the timer is not working properly and will need replaced. Click Here=> MQU1556AEW Unit parts number 15 in photo is defrost timer. The defrost timer is part number=> 4357124 Defrost Timer Check for air leaks around door seal as this will cause the same symptoms. If by chance the defrost timer works and the defrost does not then let me know here or here=> Appliance 911 The only other parts are the defrost heater number 16 in photo MQU1556AEW Unit Parts and part number for defrost heater is Click Here=> 8201749 If you change the defrost heater it is always good to replace the defrost thermostat number 18 in MQU1556AEW Unit Parts The defrost thermostat is part number=> 1-81801-001 The most likely problem is the defrost timer but I needed to cover every possibility. If you have questions please feel free to ask, Thanks, Sea Breeze
Oct 10, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
I have a maytag upright freezer. It is on the coldest setting. A bowl of water on the bottom shelf freezes overnight. The middle one is freezing, but not entirely. The top one is still water, but cold....
check to make sure door seals are touching the frame all round, could be an air leak,also make sure there is no ice build up around the inside casing. if so fully defrost unit,clean all vents/drain pipe, then turn back on and leave it for 24hrs (freezers work beast when full).....and door shut..how many times have you closed door after them????
Mar 01, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Maytag upright freezer (MQU1556AEW L1)top shelf
my maytag freezer not wotking correctly, the top shelf not cold, I bought a meat and tryed to put it on the top shelf, unfortunately, my meat went to the garbage and just the botttom shelf takes time to freeze, better than the top shelf
any help ?
Jan 02, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
GE Freezer Not Freezing
I am not an expert, but if the defrost heater is not working, then maybe when it was unpluged the coils didn't completly unthaw. If not, the freezer still will not cool properly.
Mar 25, 2009 | GE 13.7 cu. ft. General Electric Upright...
Not freezing equally
Look for frost build up on back wall at bottom the auto defrost may be out. Check if the evaporator fan is blowing. If not it's stuck by something or needs replaced. If not The sealed system may have a leak or restiction causing it to only work closest to the evaporator i.e. the lower shelf.
Apr 22, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Freezer frost
An upright freezer that is not frost free will have the coils in the shelves (shelves are non-removeable) and that is where the frost will buildup.  If your model is like this then it will have to be defrosted periodically.  If your not sure then give me the entire model # from the sticker inside the freezer and I will look it up for you.
Oct 16, 2007 | Amana 19.7 cu. ft. / 558 liter Upright...
Freezers Logo
909 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
