Question about Maytag MER5870 Electric Kitchen Range
My oven won't heat past 100 degrees. I haven't received a trouble code or anything, just started not working this way. The heater element was replaced last year and the only other out of sorts thing that I noticed was the indicator light on the front burner seemed to stay on well after the burner had been turned off and cooled down. Any ideas???
  • ppeaches Sep 23, 2008
    Hi rickzilla,
    I have tried cooking in the oven up to 375 degrees. The oven reads that it heats to 100 degrees and then doesn't go any further in heating at that point. The inside of the oven is slightly warm to touch, it does not get hot.
  • artsupest Nov 17, 2008
    My elderly mum has a Maytag Precision Touch Control 700 Electric Smoothtop. She sets it to 350 and it does not go above 150...can I replace a temperature probe myself if that is the problem?
Rick:
Thanks for your response. Can tell me where I can find the eoven base page?
Thanks. M&M
Posted on Oct 01, 2008
  • 706 Answers
Hello ppeaches,
Are you sure that the oven isn't heating up more than 100 degrees or are you basing the problem on the ovens readback of 100 degrees? If it truly isn't heating more than 100 degrees then anything inside there should be hot but not so hot as that it can't be touched. Have you tried to cook anything in there? My intent to assist in diagnosing the problem is to determine if it is a control based or read back based issue? Try cooking something that requires at least a 350 degree temp and get back to me on what happens... We;ll get you running after that,,,,,
Posted on Sep 22, 2008
  • Rick Gelin
    Rick Gelin Sep 24, 2008
    Hi Again,
    Thanks for the feedback.. based on your test and the fact that you've programmed the temp to 375.. and that the actual temp was only 100 or so.. then in all probability you have a bad oven sensor... The wat it works is like this.. you set a temperature of XXX and the heating element is turned on until the temperature is reached.. the temperature is reached when the tempertaure sensing probe feedback equals that of the programming.. http://www.pcappliancerepair.com/cgi-bin... Here is a link for the oven sensor probe..and here is a link of the parts breakdown surrounding it. If youlook at item #5 on th eoven base page.. that is probably the problem component... With power removed and someone with some mechanical aptitude, it can be replaced fairly simply.. At the very least, I would unscrew the mount for it and verify that it is still properly plugged in.. This may require accessing the wiring from the backside of the oven... Hope this helps you..
Bottom oven will not heat up past 230 degrees
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 15, 2011 | Maytag Gemini 30" Self-Cleaning...
It turns on but won't heat past 100 degrees.
heatman101
Sep 26, 2010 | GE Profile JS968 Electric Kitchen Range
F3 f1
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 27, 2009 | Maytag MER5870 Electric Kitchen Range
Fault code f1 came on during a cleaning -
On maytag f1 means there is a problem in the control (erc) and will need to be replaced.
Dec 26, 2007 | Maytag MER5870 Electric Kitchen Range
Maytag MER5775Q Electric Kitchen Range
heating elements are usually good or failed with nothing between so unlikely to be the element. problem probably lies with the thermostat. to check, bypass the thermostat and check the oven gets really hot.
May 17, 2007 | Maytag MER5775Q Electric Kitchen Range
Electric oven does not heat up enough
I had the same problem before the warranty expired. The heating element had exploded and there was white powder all over the inside of the oven. They replaced the heating element and it works as it should, however, this oven has never baked right. It gets hotter on the right hand side than it does the left and I have to constantly watch whatever I bake. I'm not very happy with this oven.
Apr 27, 2007 | Maytag MER5755QAS CleanDesign Electric...
Maytag MER5870 Electric Kitchen Range Logo
693 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
