Question about Refrigerators
Fridge freezing up on back wall of fridge not defrosting
    Genius:
  • 1,122 Answers
Is freezer fan working?remove freezer back wall put frig. in defrost,watch freezer to see if the heater is melting the ice,if not wait 20 minutes till freezer out out of defrost and fan comes on,if it does you have a bad heater and bimetal switch (the little silver round thing clipped on coils,let me know-mike
Posted on Sep 22, 2008
Samsung refrigerator is freezing up on back panel of refrigerator . Will defrosting the whole unit do any good? The unit is 2 years old
well yes and no , defrosting it will temporally make it work , but main problem is there isn't proper air flow over evaporator coils id clean them with soap and water while defrosting out unit , if low airflow is allowed to continue then refrigerant gas will build to high press and escape and render unit a total replacement
Sep 29, 2016 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
4.0 magic chef freezing on the back wall
you have a defrost component not working , timer , thermost , or defrost thermo
Nov 29, 2013 | Magic Chef Refrigerators
TOP HALF OF FRIDGE COVERED IN ICE AND FREEZING FOOD/DRINK
I have had this problem in the past. You will need to get the automatic defroster fixed or take all products out of freezer part of fridge. Remove back panel of freezer unplug from wall let defrost. put fan in front of it to speed proses. usually an hour or so depending on how badly frozen it is. good luck.
Apr 10, 2013 | Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Freezer no longer freezing and refrigerator is not cold enough either.
  1. check if the evaporator fan motor is running (inside the freezer)
  2. Same for the condenser fan motor on the bottom in the back of the fridge
  3. Clean condenser coils underneath or in the back of the fridge
  4. if there is a frost on the back wall in freezer - you've got the defrost problem, check defrost heater, defrost bimetal thermostat, and defrost timer
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The fridge back wall inside above the top 2 shelves are freezing over also the black cover on back of fridge one bit of pole going into the motor seems warm [is this normal ]
Your defrost system has failed. Defrost timer. defrost heater. Defrost thermostat. Without a model number I can not be further help.
Jun 07, 2009 | Refrigerators
Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
May 29, 2009 | Amana ABB1927DE Bottom Freezer...
Model rs21dcsv freeze is working but fridge is not working
CHeck to see if there is ice built up on the back wall of the freezer. If so you have a defrost problem. Manually defrost it then take the back wall out of the frezer and check ohms on the heater if heater is ok then replace just the defrost timer and thermostat. If heater is bad replace all three.
Nov 18, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
