Question about HP Office Equipment & Supplies
My printer won`t print document ( DeskJet 820Cse )
  • natanlitvins Sep 25, 2008
    Nothing help.
    Hello! I payd for your help: invoice # 72339 from 09/22/08
    i don`t see your help. i need printer tuday, not tumorrow.
    -My printer won`t print document - ( DeskJet820Cse)
    In properties HP DeskJet820Cse I push the button "Print test page"
    it`s doesn`t print. i wait five!! min...- Ansver: there was error
    found when printing the document "Test Page" to LPT1
    What should I do .
    Brigadier General:
  • 6,966 Answers
If all else fails, might you want to try and verify how your printer is connected to your computer. The error message says "LPT1" and if you are using USB, then of course there is no printer connected to LPT1. What is required is to verify your printer properties, port settings and make sure that the USB is checked.
If on the other hand, your printer is connected using parallel cable (not USB) to the LPT1/parallel/printer connector of the PC, and assuming the drivers were installed right, then perhaps what it needed is to try the settings of the LPT1/Parallel in the CMOS/BIOS. There are a couple of choices among them EPP, ECP, Normal. Pls cycle on each and determine which one will work.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 29, 2008
    Genius:
  • 1,269 Answers
Go to Printers and Faxes > Right-click the default printer icon (DeskJet 820Cse) > Properties. Go to Ports tab and select USB Virtual Port (check the box) then click Apply. Go to General tab and click on Print Test Page. That should do it. You'll just need to use the USB port not the LPT1 port.
  • 234 Answers
These are the steps for windowsxp
For windowsVista after control panel go to Printer or hardware and sounds to go to printers
First check the printer icon. ( Make sure the printer is turned on during this process)
Go to Start> Control Panel (or setup then contro panel) and then go to Printer and faxes (or printers and other hardware)
And check that the printer Deskjet C820se has a check mark.
If not right click on the same and left click on Set printer as default.
Next make sure the printer icon says 0Ready.
If not right click on top of the Deskjet C820se icon and left click on Clear all documents (untill it says 0ready)
If it still does not say 0Ready.
Then Go to Start> Then Run> in the run Box type services.msc and click Ok
Now in the services window> Scroll down an locate for Print Spooler and double click on the same>
Now under Services status If Start is highlighted Cliick on start ( now a small window aill poppup and close)
If Stop is highlighted then click on stop ( A small window will popup and close, Now you will see start highlighted> Click on start and then either click on apply or ok close all the windows and restart your computer.
Now First
And check that the printer Deskjet C820se has a check mark and if it says 0Ready.
If yes Right click on the same icon and left click on Properties.
Now in this window towards the bottom right you will see a tab which says print test page>Click on it to see if it prints a test page.
If yes then Try to print a document.
If non of this works>
And deleted any or all the icon which says Deskjet C820se.
If it is not deleting then right click on the same icon and lecft click on cancel all documents> Then unplug the USB cable which is connected to the printer end and leave it unplugged for atleast 1Mins before reconnecting>
After reconnecting it should install the printer diriver on its own>
Then
Go to Start> Control Panel (or setup then contro panel) and then go to Printer and faxes (or printers and other hardware) then Deskjet C820se.if it says 0Ready>Right click on the same icon and left click on Properties>
Let me know if any problem
Good Luck
Posted on Sep 22, 2008
  • HP Master
  • 13,433 Answers
Is the printer installed correctly? goto start -> printers and faxes -> select your printer and select print test page, what happens?
    Genius:
  • 3,422 Answers
If you have not installed your printer drivers then please click on the below link to download and install it.
If you already have the drivers and cannot print the documents then reinstall your drivers.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?lc=en&cc=us&softwareitem=dj381en
I connected to my HP DeskJet 820Cse via my home network. It showed the printer is connected and selected but won't print. I am using Windows 7 64-bit. What's wrong?
The 820 is a really old piece of kit and i am very surprised that windows 7 has found a driver for it. I I suspect that it has used a generic driver as hp never produced a W7 driver let alone a 64 bit one. I dont think you will ever get it to work.
Srri but have been working on printers for over 20 years so take my advice and dont try and cure the incureable!!
Jul 23, 2011 | HP DeskJet 820Cse Printer
Printer does not pick up paper to print.
The rollers may be dirty and slipping. I just fixed this problem on my old HP 820Cse by cleaning the three rollers with rubbing alcohol (99% isopropyl alcohol) as follows:
1) Remove the paper tray. The release lever is under the tray.
2) Saturate a small 4-layer pad of paper towel with the alcohol.
3) Try to print something. The rollers will turn. While they turn, hold the alcohol-soaked pad firmly against one roller.
4) Repeat 5-10 times for each roller until no more black stuff comes off. (Push the button next to the printer's amber light to repeat the print cycle.)
5) Slide the tray back in. You're good to go!
--(posted 9/13/11 by Donjo)
Feb 17, 2011 | HP DeskJet 820Cse Printer
Deskjet 820cse wont feed paper
try using lemon juice n cleaning the rollers at the bottom probably slipping on paper
actionman
Mar 01, 2009 | HP DeskJet 820Cse Printer
New Dell Inspiron connected to HP 820Cse printer. Won't print.
I've not worked with one of these cables before, but here's what I would do: Right-click on the printer icon and go to properties. You'll be looking for the tab that says "ports." Open that tab and see what port the computer thinks it's using for the printer. Chances it says it's using a parallel port, but it is in fact, using a USB port. I can't tell you which to choose without looking at what you see, but I think you might find one that makes reference to a USB port with a parallel connection of some type. Try clicking on that and see if your situation improves.
Feb 24, 2009 | HP DeskJet 820Cse Printer
Does not print
get a new cartrige
Feb 11, 2009 | HP DeskJet 820Cse Printer
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
Print alignment
hi, the printer has rubber rollers which pulls the paper in during printing, it seems like one side of the intake pully does not have enough presure or the rubber has hardned or worn out, hence it is slipping off,check that area , let me know.
Dec 16, 2007 | HP DeskJet 820Cse Printer
Paper feed
hi, do you notice any intake activity when u hit print in word etc???check word print properties.. let me know
Dec 09, 2007 | HP DeskJet 820Cse Printer
Printer problem
Hi, after you install a new ink cartridge you need to run the printer software to add the new ink levels. Have you done this?
Sep 15, 2007 | HP DeskJet 680c InkJet Printer
551 people viewed this question
Seeker5211
Seeker5211
