Question about Panasonic KX-T7633 Corded Phone
Reverse order of voicemail playback (oldest first
How do you change the order that voicemails are played back? I would like to receive the oldest message first and currently I get the most recent message first.
  • Panasonic Master
  • 2,460 Answers
On a Panasonic voice mail system, it's a Class of Service option. You, or your dealer, will need to create another class of service with the Message retrieval set to FIFO and assign your extension to it.
Depending on your actual VM system, you may be able to modify it by phone, but it's better and easier to do it from a computer where you can compare the parameters of both classes of service.
Carl
Posted on Sep 22, 2008
I am unable to get voicemail messages
Hi I may be wrong or not have all the facts, But, At first glance, voicemail is not an App or service that is associated with the iPhone 4 itself. How would you "edit" voicemail?? This service would be with your mobile service provider, therefore you should be able to call from any phone and check your voice mail. Here in Australia I delete Telstra voicemail by hitting 5 after the message is played back. Hope this helps solve your problem.
Jun 13, 2014 | Apple iPhone4 4G iPhone 4
Voicemail change message
How To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
How To Record Your Alternate Greeting (Used when on vacation or out of the office.:1. Press the Check Voicemail key or press the Feature button, then 981
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the Choose softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting.
Nov 21, 2013 | Nortel T7316E 2-Line Corded Phone
Voice mail playback speed is s...l...o...w... how do I reset it to normal playback?
The assumption is you are using Unity connections.
Complete these steps in order to change the speed:
  1. In Cisco Unity Connection Administration, find the user account or template that you want to edit. On the Edit menu, click Playback Message Settings. Set the Message Speed to Normal.
  2. If the users make any changes while they listen to voicemail, they are saved. In order to disable this, you can go to Advanced > Conversation > Save message playback Volume and Speed. Uncheck this to ensure that the changes made by users are not saved permanently.
If you are not an administrator, you can press 4 or 6 during the message to speed up and slow down.
Jan 05, 2011 | Cisco 7945G IP Phone
How can I check my boyfriend's TMOBILE voicemail from my phone
Step 1
Dial your phone number from the phone you are using to check your voice mail. Let the phone ring until the voice mail message begins.
Step 2
Press the "*" key or the "#" key while the message is playing. One of these two keys is usually the key that activates access to your messages. This will work for most answering machines and voice mail services, although some may use a different key code .
Step 3
Enter your password or passcode. For most systems, this will be a four-digit number that is keyed in and will sometimes be followed by the "#" key.
Step 4
Listen to your messages. Usually, unheard messages are played back first, followed by any saved messages on the system. Systems vary as to whether the oldest or newest unheard messages first.
Feb 26, 2010 | Motorola Mobility Clutch i465 Cell Phone
How do i retreive my voicemail on my vtech 5.8 phone?
Hello, Below are the instructions for voicemail retrieval for your Vtech CS5121-2 5.8 GHz Twin 1-Line Cordless Phone. I have included an easily clickable and printable PDF link of the user's manual for this phone from the official vtech web site. I hope this helps you!
- CBR2009
New message indication The message display counter will flash when there are new answering system messages. If the new message alert tone is turned on, the telephone base will beep every ten seconds when there are unreviewed messages. Message playback Press /PLAY/STOP to listen to messages. Press /PLAY/STOP again to stop playback. If you have new messages waiting, you will hear only new messages (oldest first). If there are no new messages, the system will play back all messages (oldest first). When playback begins, the total number of messages is announced, followed by the day and time of the first message to be played. Options during playback Press VOL+/VOL to adjust the speaker volume. Press >>/SKIP to skip to the next message. Press<</REPEAT to repeat the message currently playing. Press <</REPEAT twice to listen to the previous message. Press X/DELETE to delete the current message. The system will advance to the next message. Click below for PDF USER'S MANUAL http://www.vtechphones.com/docMgt/public/art/314062/cs5121_manual.i6.pdf
Aug 18, 2009 | Vtech CS5121-2 Cordless Phone
Where is the voice record key?
Voicemail
Your network stores the voicemail messages you receive. To listen to your messages, call your voicemail number.
Note: Your service provider may give you additional information about using voicemail.
The phone calls your voicemail phone number. If no
voicemail number is stored, your phone prompts you to
store a number
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jan 22, 2009 | Motorola Mobility RAZR V3
Receiving Fax using a phone line with voicemail on a Lexmark 5470
well, your voicemail can configure to key tone?? or have some one configuring options????
Nov 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Changing the MAIN voicemail
you have to go into the administrators vm box.
press your vm btn or press intercom and dial 777.
at enter mbx prompt.
press 99#
password= 1234
press 9
follow the prompts.
hope this helps..
Feb 22, 2008 | Lucent PARTNER18 Corded Phone
Nokia 5185
In order to change your voicemail message you need to call into your voicemail system. Voicemail is not actually in the phone but a service where your calls are forwarded to. Most voicemail systems will play the main menu if you press the * key. One of them should be about a greeting. Check with your carrier for specifics.
Feb 03, 2008 | Nokia 5185i
I want to change the # to access my voicemail
Go to Main menu, then "Messaging". Within Messaging go down to "Message Settings". #3 is voicemail. click voicemail and you will be able to edit the number.
Oct 25, 2007 | LG Shine KE970 Cellular Phone
Panasonic KX-T7633 Corded Phone Logo
87 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
