Question about Hotpoint Aquarius WMA56 Front Load Washer
My hotpoint wma56 wont do its fast spin cycle
Basically it will do the whole cycle , however some times it finishes with the fast spin and other times it doesn;t, hence the washing is soaking when i take it out. has any1 got any soloution???
  • k3mpy Mar 07, 2009
    WMA56 does its wash cycle okay but gets stock on fast spin, the light just keeps flashing and clothes remain wet
    Sergeant:
  • 282 Answers
May need a new or reclaimed Motherboard / Circuit board,
if the pump and pipes are found to be clear.
Posted on Mar 01, 2015
    Problem Solver:
  • 13 Answers
Have you checked and cleaned the filter on the machine, usually located and the front near the bottom. If so then there is 2 other possibilities, either your water pump at the back of the machine is blocked or faulty, or it's the timer on the machine. A washer won't go into spin mode until it has drained all the water from the machine first. hence the pump has to run. Just remember to drain all the water from the machine before checking your filter otherwise it will end up on your floor.
Posted on Apr 11, 2009
Wont spin and the front indicator lights are going from pre wash to end in a night rider fashion
try checking ur door switch may also want to check the water pressure switch which signals the machine to go into wash after the fill cycle
Feb 11, 2015 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
Hi, my Hotpoint Aquarius wma56 washes, but drum wont spin in rinse and wont spin...any advice?
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear.
Jun 10, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
It wont do final spin..makes a clicking noise as it turns the drum during spin
I moved my washining machine in order to check pipes....thought id do a final test spin hoping that it would work changed the temperature setting to higher degress (60) put in on a empty wash for about 5 mins then turned it to fast spin an it slowly started spinning until it finished a complete spin!!!!...dont forget to turn the temperature down again!!!
Aug 23, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Washing machine not spiining
sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
Dec 10, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WMA56 Front Load Washer Logo
605 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
