Question about Electrical Supplies
Coleman Powermate 5000
Hi, I'm new to FixYa so hopefully you can help me. I posted a premium question last night about my Coleman Powermate 5000 and received an e-mail that you had posted a solution. However when I looked at the question in my profile, there is only an answer from swami nathan.
Am I missing something?
  • sal sabea
    sal sabea May 11, 2010
    your problem please?
  • J. Bradshaw May 11, 2010
    What is your problem with the generator??
SOURCE: Oil for Coleman Powermate 5000 PM0545305.03
Engine is loaping. I have changed the gas stc. Still loaping. As engine loaps, the lights dim and small ac window unit will not run property.
Posted on Sep 21, 2008
CarlGehrke
  • 169 Answers
SOURCE: What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Posted on Dec 15, 2008
  • 195 Answers
SOURCE: Coleman Powermate 5000 no electricity, runs fine
Hello;
Take a look at your outlets. Some of these units use pretty cheap outlets and short out. You will know if it is bad when you look at it. Hope this helps.
Thanks;
Rich
RPM Northwest
Posted on Jan 23, 2009
saumyar
  • 174 Answers
SOURCE: How can I get a owners/instruction Manual for my
follow this link to get the user manual guide as per your model no:
http://arkansas-ope.com/COLEMAN_GENERATORS.html
Posted on Jun 08, 2009
al_kupchella
  • 843 Answers
SOURCE: i cant get my coleman powermate 5000 MAXA ER to
It's almost certainly gummed up gas in the carburetor. Get some carb cleaner, and some spray instant start. Drain the gas from the tank and put a small amount of 50/50 carb cleaner and gas in the tank. Remove the air cleaner, open the choke, spray a little instant start into the carb and start it. It may fire just a couple of time. Keep the choke on to try to pull a bit of gas through the carb. You may have to do this a few times. Once you can tell some gas is flowing, open the choke slowly to keep it running until you use up the 50/50 mix. Then try a small amount of straight gas in the tank to be sure it works right, before you refill the tank. Make sure you use a stabilizing additive in any gas that you store for more than a month. good luck, Al K
Posted on Feb 02, 2011
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
How many watts is the Coleman Powemate Premium Plus 6250W portable genr
Hi, the constant delivery is about 5000 watts and the peak delivery is as the name says 6250 Watts. Hope this helps.
Nov 18, 2010 | Coleman Powermate Premium Plus 6250W...
Operators manual
Here is the website for manuals:
http://www.powermate.com/productmanuals.php?cat_id=3
You will need the actual model number of your generator.
Thanks for using Fixya.
May 08, 2009 | Coleman Powermate Premium Plus 6250W...
I have a coleman powermate 6200 that puts out no elecietety
Here is a link to a general solution I posted some time ago.
If that doesn't solve the problem let me know.
Regards,
Carl
Feb 22, 2009 | Coleman Powermate Premium Plus 6250W...
Hello;
Thanks;
Rich
RPM Northwest
Jan 16, 2009 | Coleman Powermate Premium Plus 6250W...
Need a Manual Coleman PM 6560 & side plate. wHERE TO FIND?
Hi wolfin13,
From
http://www.powermate.com/contact.php
Generators / Presure Washers / Home Standby: Customer Service: 1-888-977-2622 Technical Service: 1-800-445-1805 Email: generatorservices@powermate.com
As part of my research, came across this entry from another FixYa expert with some additional info.
http://www.fixya.com/support/t1008210-coleman_powermate_6250_generator
I hope this gets you what you need. If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Jan 03, 2009 | Coleman Powermate Premium Plus 6250W...
Need to know about this generator. Coleman Powermate 6250 Gen power 305 5000 running watts Model PM0545008 Serial # E06601199B
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Dec 05, 2008 | Coleman Powermate Premium Plus 6250W...
Oil to gas ratio for Coleman Powermate 5000?
my powermate is straight gas.......be careful. go to colman web site and download service manual. mike
Nov 18, 2008 | Coleman Powermate Premium Plus 6250W...
Oil
Coleman 018-0060ct air compressor oil or equal
most hardware stores will stock it.
Aug 31, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
