E6 - Drain pump error
Water level does not decrease to reset point within 15 minutes from draining water from the washer.
Press POWER button. No other buttons work: · Check wiring harness · Check pump motor · Check circuit board
0 or F7
Shorted Clear/Off Key due to membrane switch, control or connector
Shorted key panel membrane switch; Check Electronic Range Control (ERC)
F7 E6 shows that Function pad button stuck or Bad clock try to Unstick Button or Replace Clock also if persist then check the connections to the contol panel
The code is because of bad keypad/the control panel.Have it changed.It probably non-functional and constant beeping sound is followed as you mentioned.Theres a link to explain more about this for reference.The only solution is to replace the control panel.
F7 is a stuck key. Usually you can't get a key unstuck. Best thing to do is replace the keypad / user interface. Here are some of GE's error codes:
GE Range/Stove/Oven Fault Codes
Failure CodeConditionCheck/Repair
F0 and F1
Failed Thermistor Control
Replace Electronic Range Control (ERC)
F2
Oven temp exceeds 590 w/ unlocked door
High resistance or interference in oven temperature sensor. Replace oven temperature sensor
F3
Open oven temperature sensor circuit
F4
Shorted wire (Oven temperature sensor)
Locate and correct
F7
A = Function pad button stuck or B = Bad clock
Unstick button or Replace Electronic Range Control (ERC)
F8
Component Failure
F9
Program w/ door circuit
Check wiring
I just read that the electronic panel malfunctions due to rear burner use. Now, I know that mine gets REALLY HOT in between the back burners (where the heat exhaust for the oven is) whenever I bake/broil. I am guessing that it can cause the same malfunction fromt he oven, as with the backburners. Whenever I use both back burners, mine shows F7 E6, too. Unplugging it for the night or just waiting til the beeping stops and then clearing it works... until I cook again. I read that the replacement part for the control panel is about $300 and another $200, more or less, to install it! I think this is more like a recall or manufacturer's problem. I have read plenty of complaints and I think GE needs to make a call to fix them!!
