I bought the Samsung, SyncMaster913v 19' Monitor, over 1 year ago. On weekend we had a powersurge and after the monitor could not turned on. All that happens is a green ligth blinking at bottom of screen, which gets turned off as you push powerbutton. I have a qoute to fix for $120, but is hoping you can tell what was "fried" and what I may need to buy, and how to replace?
  • johangrandin Sep 22, 2008
    I already replaced, but would like to keep this old one for my kids.
  • 3 Answers
Its toast. Cheaper to replace with an lcd. jmo.
Posted on Sep 22, 2008
I bought a SyncMaster 2333 monitor 1 and half year ago. Suddenly, my monitor does not show anything. Turn on/off switch is not working. Sometimes it shows just bluescreen. I am wondering what is wrong and...
This problem usually indicates a failure of the power supply board that runs the video control board. You can fix it but if your unit is only 1.5 years old then its still under warranty, 3 years parts and labor. Go to www.samsung.com and go to the service section to start a warranty claim. It takes about 2 weeks to go out and back to you.
BuddyMc
Feb 27, 2011 | Samsung SyncMaster 2333SW 23" LCD Monitor
Samsung Syncmaster913v Monitor. The screen is totally black, but when I remove lead from computer it shows "Check Signal Cable" in colour. Also when I press Menu, in top left hand corner...
If the color still works, and it works on other computers, there is something wrong with the computer in question. But this is not the case, so logically, something is wrong with the monitor. Check the cable for broken pins.
Feb 11, 2011 | Samsung SyncMaster 913V 19" LCD Monitor
I have the same problem
Speak more about the problem, do so we can help you! Thankyou my friend!
Sep 14, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
"Not optimum mode" on SyncMaster913v monitor
In Windows (since it's a laptop I'll assume you're running Windows XP)
right-click on the desktop, select properties, and go to the settings tab.
Click on the display with the 2 in it, then set the resolution to 1280*1024.
If that doesn't work, you should check wether the desktop is extended to that display, or cloned on it. It should be set to the first.
by the way, in safe mode the resolution is always set to 800*600.
This should fix the problem!
If it doesn't, just post what happened here.
Sep 09, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Monitor turns on for less than a second, then off. I bought a 19" Samsung LCD monitor (953BW) about 10 months ago and the first time I used it, it would only switch on for a split second and shut down. ...
Although the OP was 2009. I had this problem.
I simply replaced the power board. Which I bought from ebay for $20AUD.
It was real easy to remove as well. Just have a look for youtube videos.
Fixed!
Aug 31, 2009 | Samsung 953BW LCD Monitor
19 in lcd mag monitor
You need to try another monitor, any type. If you find another monitor does functions return the 19" monitor. Most monitors come with a 1 year warranty.
Feb 12, 2008 | Mag Innovision LT976S 19" Flat Panel LCD...
SyncMaster 920n Power Cable (?) Issues
I think my monitor power connector broke too
Sep 29, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
Samsung 940mw intermittent power...
I don't have a solution but would like to compare information as i just started looking into this problem myself. 1. I bought my Samsung 940mw in March, 2006 but didn't start having problems with it until around April, 2007 2. I'll be using it as my pc monitor when the screen goes black and the power light stays solid green. The monitor doesn't respond to the remote control. Nor can i manually turn it off via power button BUT i can restore it by a) turning power off at the UPS outlet it's plugged into b) removing the monitor cable from PC port c) restoring power and waiting for the Samsung diagnostic message about no monitor detected then d) plugging the cable back in. My monitor image reappears. 3. fyi I only use the analog monitor input. Samsung also released a new driver which hasn't made a difference. Within just last couple months the monitor will sometimes just go black a coupla seconds and come back on without any intervention
Jul 31, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
