RCA 8030N Menu/Signal Problem
Hi !
My wife did something I cannot figure out, when she exited from viewing a DVD on our RCA 8030N DVDR/Hard Disk. The machine will now power ON to the 'Menu' display on the front screen -- but I cannot get a menu or signal to show up on the TV.
In fumbling through the remote, I've gotten a signal detection (but no image) by setting the Input to Line 1/Line2 (? Live 1/Live2 ?) and "PS Off" selection.
I've powered the machine off for several hours to no avail.
The clock shows the correct time-of-day (from its auto-set feature, I'm sure).
Any ideas how to get the Menu to display on the TV?
Is there a way to reset the machine (without loosing its hard disk contents)?
What does "PS Off" (or On) mean, anyhow?
Is there a User's Manual you can Email to me?
Thank you!
  • 26 Answers
SOURCE: RCA F32450 TV can not get the TV to display the DVD menu
You can get a remote from for $29.95. The remote number you are looking for is RCA-GE-PROSCAN 242524
Posted on Nov 17, 2008
  • 17 Answers
SOURCE: my computer stopped suddenly and did not detect hard disk
restart your cmos by removing the battery on your motherboard and if that doesn't work update your bios.
Posted on Dec 20, 2008
SOURCE: How do I set the correct input channel for S-video from laptop
press the video/tv button on your remote control until it gets to video or input 3
Posted on Feb 18, 2009
SOURCE: video input selection remains displayed - can't get rid of it
The solution to your remote problem is to go to wal-mart and when you go through the check out lane there is usually some last minute items. there is a silver remote that is usually hanging in those aisles and that has been the only one I have found that works.
Posted on Mar 07, 2009
SOURCE: Basic Cable (no box); signal "in" to DVD Recorder (from TV)
Problem solved via tech support for Toshiba- thanks!
Posted on May 05, 2009
Installing window 7 but cd pc not booting from cd
Windows 7 installer is not a CD it is a DVD installer. Cd drive can not read a dvdrom (dvdr or dvdr/w). You must have DVDrom drive to install the windows 7 installer. Here is the video tutorial on how to install windows 7 have a nice a day!
May 27, 2011 | Computers & Internet
Hi! I need help with my computer. I use a seagate ST380811AS hard disk in my desktop computer. The problem now, is that everytime I start my computer "A non system disk" appears on the monitor or...
1 Remove any floppy disks or bootable CDs, DVDs, USB flash drives or other bootable media from the computer. Attempt to restart the computer again. Proceed if you continue to receive the error.
2 Restart the computer again. Press the key required to enter your BIOS setup. (The monitor usually displays a "Press [key] to access BIOS" right after restarting your computer. Press the key shown on your screen.)
3 Navigate to the "Boot Options" or "Advanced" menu by using the arrow keys. (The precise menu terms will vary according to your computer and BIOS type.)
4 Select the hard disk that contains your operating system (usually C:) as your primary boot device. Select your CD/DVD drive, your floppy drive or another hard disk as your secondary boot device.
5 Save and exit the BIOS. Proceed with the next step if you see the "Non-system disk error" message again.
6 Restart the computer. Return to the BIOS' "Boot Options" screen by following the steps above, then set the "CD/DVD drive" as the primary boot device and the hard disk as the secondary boot device. Save and exit the BIOS.
7 Insert your Windows installation disc. Restart the computer. Press any key to boot from disc. Follow the on-screen prompts to reinstall Windows.
8 Replace your hard disk drive if you cannot install Windows.
Thanks for choosing Fixya
Mar 19, 2011 | Computers & Internet
I have a Sharp Aquos with a optical output, i conected it to the tv optical input of the panasonic sc ptx7 but it doesnt have audio via optical,on the contrary via rca works perfectly.
check the following on ur tv
1. Press MENU to display the MENU screen,
and then press c/d to select "Digital
2. Press a/b to select "Audio Setup", and then
press ENTER.
3. Press a/b to select "PCM" or "Dolby
Digital", and then press ENTER.
4. Press MENU to exit.
PCM The optical output terminal output studio signal in PCM form. If your digital audio system does not support Dolby Digital, select "PCM".
Dolby Digital
The optical output terminal outputs audio signal in Dolby Digital form. it reproduces sound from surround program of digital.
also check the input assignment of ur dvd palyer's tv input. if it is selected as analog then change it to digital.
Dec 20, 2010 | Panasonic SC-PTX7 Home Theater System With...
I have a iLO DVD recorder,it will turn on and show menu on front of unit but I can't get the menu to come on screen of TV.It is model #DVDR05/ZU.. You put a DVD into unit and push play on remote and it...
I have a DVDRo4 model so they may not be the same. I connect 3 wire RCA cables to the DVDR output and to TV 3wire RCA input. I set the TV chan to Aux. I set the DVDR souce button to disc. Hope this works on you unit 05
Nov 22, 2009 | iLO DVDR05 DVD Recorder
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mar 25, 2009 | ASUS A7V133 Motherboard
Code for remote control of philips DVDR 3360D Hard disk / DVD Recorder
Also need to know what is the make and model of the universal remote you are using. Codes vary from one to the next.
If by chance your remote is Philips, the code for Philips DVDR's is one of the following:
0599, 0699, 1211
I have a Philips URC US2-PH5DSS and I use the code 0599 to control my Philips 3355 DVDR.
Apr 15, 2008 | Philips DVDR 3355 DVD Recorder
How to exit service menu
Try this
Use the CLEAR button / long press on the MENU button to toggle between user and svc menu. Press EXIT button to exit svc menu.
Mar 18, 2008 | RCA 20F420T 20" TV
Need help with PIP
When you go into the menu to choose the PIP source the PIP comes on to confirm that a valid source has been selected. It is normal for the PIP to close when the menu is exited. To display the PIP normally you will need a remote with a PIP button. Most universal remotes today have PIP functions but if you get a Zenith original replacement then you are guaranteed to enjoy the other PIP features such as size, position, freeze and swap.
Jul 25, 2007 | Zenith Z36X31D TV
RCA RC5215P DVD Player only plays in black & white
Dear brother at first u insert a original copy righted disk and check .And there is an option for swithing in menu for PAL and NTSC.And also please check ur TV is supported NTSC3.15 colour system,If not check ur player in a multi system TV.
Dear brother if u r a technician please can u mail me the IC number of IC104 in signal board under the lense mechanism in the same RCA RC5215P DVD player,becouse I have missed this IC from my player
Jul 15, 2007 | RCA RC5215P DVD Player
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
