Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
My power company shut my power off during the night and the next morning my $100. Cuisinart Grind and Brew 10 cup Coffee Maker- Black, serial #40219C would not work. Is there any hope for me.
  • 1 more comment
  • jimzalenski Sep 29, 2008
    Exact Same thing..minor power outage overnight and now no power at all to the machine. Tried multiple outlets in the house. It never had any issues prior to this.
  • arby134 Oct 12, 2008
    Same thing, same model too. I the Cuisinart grinder plugged into the same outlet doesn't work either. What gives? Is there an internal fuse or something?
  • smolcich Oct 14, 2008
    I have the same problem and I have unpluged it and let it sit and also pluged it into another outlet. Still doesn't work!!!!!
    Brigadier General:
  • 5,158 Answers
What exactly is it doing or not doing ??? any lights come on when you attempt to use it. chances are it just needs to be reset (unplug it for about ten minutes then plug it back in).
Robert
Posted on Sep 22, 2008
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
My cuisinart automatic grind and brewthermal shuts off every minute or so it douse not brew strate through.
HI,
• Remove the hopper from the unit
• Lift coffee channel cover
• Clean out coffee chute
• Replace channel cover and hopper
• Your coffeemaker is now ready to brew again
Oct 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
How do I clean the Cuisinart Automatic Grind and Brew Thermal coffee maker
I clean mine once a month with 6 cups vinegar and a couple cups of water. also replace the charcoal filter regularly.
Jan 14, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 cup coffee maker warm water leaks from bottom during brewing.
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Oct 12, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker
hi
check your settings, or maybe you have defective thermostat...
Thanks
Coffee maker shuts off during brew
Unplug for 20 minutes or longer, then:
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Aug 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
266 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
