Question about Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon super g-3 copier
I have a problem with the error fax light not shuuting off. Ever since this has happened I can not use my letter paper tray. It always tells me to check the paper. I am having to load letter paper in the legal tray and fool it. do you have any suggeationjs on how to fix this. I have read and looked all through the manuels and it says nothing. Your help will be greatly appreciated.
Thank you,
Kelli
  • 4 Answers
Need to know what kind of fax this is
Posted on Oct 01, 2008
What does E02 mean
PDF]canon printer error code e31.pdf - WordPress.com
https://maitioprolur.files.wordpress.com/.../canon-printer-error-code-e31....
... on Canon. Printer MP287 : E02 E31 Cause : The printer is not connected to the computer ( the printer is ... Canon Pixma MP287 All in One Printer List of Error Codes There ... Cartridge: Canon E31 Toner CANON Printer + Copier + Scanner -.
Aug 26, 2015 | Canon PIXMA Office Equipment & Supplies
What does error 60.03 mean?
This has to do with the paper lifter for tray three. There could be any number of problems with the lifter or tray;
1. incorrect paper size - i.e. someone loaded letter in the tray that is mannually set to legal and didn't change the manual paper slider to letter or papers stuck in the tray,
2. manual paper lifter isn't working properly, motor spring could be broken or out of place,
3. the paper tray could be broken and you will need to replace the tray.
First check that the correct size paper is loaded properly in the tray and that there is no paper detritis stuck anywhere. If the tray has the correct paper and there is not paper detritis then swap tray 2 and 3, reboot the printer and see if the problem moves with the tray - it should become a 60.02 error. If this happens then it is a tray issue. If you still get a 60.03 error then it is a tray 3 lifter motor issue, here is a link that explains what needs to be done.
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1297720042315+28353475&threadId=1389969
A lot of the time there is a loud pronounced clicking or banging also associated with the problem. The noise happens during the paper pathway test shortly after you turn the printer on and will display the 60.xx error code instead of the ready status.
-Connie
Jan 11, 2011 | HP LaserJet 4700 Printer
I am getting a "fax output error - cassette." It
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes successfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Dec 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Our machine is reading error, with "incorrect paper size". What does this mean?
This error means that either the physical paper tray and copier setting dos not match up with one another. For instance, if the tray 2 is set to letter and the copier is set to legal on tray 2, then there will be a discrepancy and cause an error. Ensure that both the tray and copier are set to the correct size.
-David.
Nov 05, 2010 | Canon Office Equipment & Supplies
Fax output error
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes sucessfully or you can put paper in the cassette tray...
Hope that helps.
Mar 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
My canon mf3240 printer jamed, then a b5 paper size error message
You must be set you machine from program key
1> press menu>paper size>A4/Letter/set OK
after print or copy your requirement size.
Dec 12, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Paper Size
double check the menu section is it set for Letter?
check the tray do you have Letter paper in it, are the guides set correctly?
Aug 19, 2008 | Canon LaserClass 2060 Fax
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
"wrong size paper"
Change the cofiguration of the size in your fax machine see if accepts them then
Aug 16, 2007 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
688 people viewed this question
old marine
old marine
