Question about Apple iMac G4 Desktop
Imac the older one ball like base
My computer keeps bringing up a screen thats is chinese writing and freezes and say shut down computer. this keeps happening. what do you think is wrong?
  • 18 Answers
I don't know what is wrong, but I'll bet it can be fixed by reinstalling your Operating System. You will have the option of archiving your old system, and the files won't be touched.
Posted on Sep 26, 2008
My imac keeps freezing withen 3 hours.
You can do this with the built in program Automator. Hit record and Automator will follow your actions and turn them into a script. You can then set the script to run in the interval you requested.
Nov 10, 2013 | Computers & Internet
When it comes on it want stay on but for 5 or ten min
Turn off computer and restart and hold down the D button while it boots on. This will bring you into the diagnostic screen. Run the diagnostics to check hardware issues. If nothing comes up reboot normally and check your power profile. It is probably set to shut down or suspend after that time to save power.
Oct 14, 2013 | Apple IMAC A1208 desktop Used
I would like to know if an older hard drive from imac model A1076 could be installed in a slightly newer imac, model A1145 and have it be compatible and working with no problems?
Hard drives are universal, and based on physical connection / type. So your older HD should work even if you have newer SATA connection. The connection is backwards compatible.
Dec 08, 2012 | Apple Imac G5 20" Als G5 2.0ghz 2gb-ram...
I have a new iMac all in one dual core 3.06GHz 4GB RAM..500GB HD memory....and when I shut down it will not close but keeps saying to force quit my Lexmark printer so it can shut down all the way? Why...
Your printers' app is keeping your Imac from shutting down. You have to quit the printers' app first then shutdown. Some outside vendors' apps (as Lexmark - has a function that prevents you from shutting down computer in case you have stuff printing) You can change that in your Lexmark preferences. And no it won't hurt the IMac, it's just a hassle until you change the printers' preferences.
Jan 07, 2011 | Apple 21.5" iMac Desktop
Locks frequently and restarts sometimes all by itself. Parts of the screen regularly skews in triangular shapes.
  • Verify that the power outlet you're using is good and your power cable is firmly connected to the wall outlet-if using a surge protector, be sure that it's firmly plugged into the wall outlet. Also, try temporarily plugging directly into the wall outlet to eliminate any issue with the surge protector; plug a different electronic device into the same wall socket to make sure the socket works, and also try the iMac's power cable in a different wall outlet.
  • Make sure the computer's power cable is firmly connected to the computer.
  • If any external devices are connected to your iMac, disconnect them and try to turn the computer on again. If the iMac will power up when those devices are removed, but not when they are connected, contact the manufacturer of those devices for assistance.
  • Try resetting the iMac's SMC
  • Remove and reinstall the SO-DIMM memory modules, located in the bottom of the computer.
  • Resetting the SMC for Mac Pro, Intel-based iMac, Intel-based Mac mini, or Intel-based Xserve
    1. Shut down the computer.
    2. Unplug the computer's power cord.
    3. Press and hold the power button for 5 seconds.
    4. Release the power button.
    5. Attach the computers power cable.
    6. Press the power button to turn on the computer.
Nov 12, 2010 | Apple 2.16GHz iMac Intel Core 2 Duo...
same thing happens to me - most of the time it will just randomly freeze; occasionally i get an unresponsive black screen. this 24' aluminum imac usually has startup problems also - sometimes it will "gong" and nothing else; sometimes the apple logo will come up and then nothing else; sometimes it will load the logo and then spin for a few seconds and then freeze - the only option is to manually shut down. there is no rhyme or reason to it
Feb 07, 2010 | Apple 24" iMac Desktop
MAC PRO dual2.3- freezes, gray screen crash, freeze with hi fan mode,kernel panic reports, all require start button shut down. Some forums suggest ATI card failure. I'm lost.
All computers will shut them selves off or crash when fans are failing, or have failed. Cooling fans are plugged into the motherboard, and firmware on the MB keeps track of the system fans, along with everything else. If a system fan is failing, or has failed, the signal is sent to shut down. Some PC's will shut down cleanly, others give error messages, and some just freeze up. Of course, Bad RAM, video cards, and hard drives with bad sectors, can also cause problems like you have discribed.
I would write down any error messages, and beep codes, and then look them up online for a place to start.
Oct 22, 2009 | Apple Power Mac G5 Desktop
IMac freezes on startup. Can't use safemode.
Safe mode just requires holding shift down during start up and if it starts up at all this should be possible. Once in safe mode, you should be able to use Disk Utility to Verify disk and Fix Permissions. To Repair disk or with/without safe mode you need to startup with your install disk and on the first screen or after selecting language, use options to select Disk Utility. You really should tell us the MacOS version--10.3.9 10.4.11 10.5.8 or 10.6 are current and tell us your install disk version, too. With safe mode you can use terminal to run fsck to fix the disk, read the man page. Alternatives include starting up in Target Disk Mode (command+t at startup) and using your computer as an external disk for another Mac by Firewire or possibly USB, fixing it using the others software. These methods in descending ease.
A now permanently dark screen would indicate a bigger problem and a trip to an Apple store for an evaluation. Tell us your iMac model--could affect whether you can easily savage your disk data in this case. -Ken
Sep 11, 2009 | Apple iMac G5 Desktop
Printer will not add to my computer
Ok, since you state that you have an older iMac, I'm going to presume that it is not an Intel-Mac and that your OS X version is Linux based. So with that information known, you will just have to search for the printer (Lexmark 3400) drivers for the version of OS X you are currently running. Since the older Mac's use CUPS instead of drivers that PC's use. Basically instead of searching in Google for a Lexmark 3400 print drivers for an iMac, you would need to instead search Google for CUPS Lexmark 3400 OS X. Then you would get a link like this:
And if you follow that link you would get to download the needed file(s). And usually the installation instruction is there on the same site. It is a bit confusing to figure it all out but if you get lost there come back and post it here and someone will help. And if i happen to come across you i will be glad to help with the confusing manual installation of the CUPS into your iMac.
- Luke
Feb 09, 2009 | Apple Computers & Internet
Problem with our Apple Macs shutting down
A quoted suggestion from my Mac Guru: "They need to turn off the Energy saver preferences for processor cycling and hard drive spin down. They would actually be better off turning them down anyway since the G5 duals run really hot and aren't the most reliable model Apple ever shipped for motherboards failing."
As for the iMac 99, It would be more helpful to know what OS the unit is running. I remember hearing a story about a disgruntled employee putting the 'shut down app' in the start up items folder. This caused the Mac to start as normal and then shut down after the startup was complete. Try starting up the machine with the extensions off. 'Hold down the shift key at startup'
Feb 09, 2008 | Computers & Internet
Apple iMac G4 Desktop Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
