Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Range will not light
Gas is persent but all burners will not light
  • 750 Answers
Hello trackphitrac ,
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, you have gas is present but all burners will not light !
What is the model number and age of the gas range.
Does it have electronic ignition?
If so did you check the breaker, that it is still on and that it has power?
If you have power to the clock or any thing else and the range has an electronic ignition,
that will not light, perhaps there is a fuse in the rang?
I need the model number!
Huuum
Posted on Sep 24, 2008
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
Caloric range oven, older at least 20 years old, the range burners spark, but will not light, i am assuming that its electronic ignition, no pilot light?
If you don't smell gas, then it is probably electronic ignition and not a pilot light.
But if your oven and none of the range burners light, are you sure you are getting gas to the unit or from the range valve to the burners and oven? Can you light the burners with a match? If you can you can rule out the valve and incoming gas line, and concentrate on the ignitors.
Jun 07, 2011 | Kitchen Ranges
I have a model 3110PRW gas range and can not get the pilot lights to light. I am getting gas through as I can light all four burners but the pilots will no ignite. It is set up for propane gas.
Hi on the burners there is a hole where the gas comes out of the burner to light off the pilot is this blocked or are the pilots blocked short pilot flame
Feb 09, 2010 | Magic Chef 31000 Gas Kitchen Range
Front burners on gas range won't light.
My GE gas range is really sensitive about the gap between the igniter electrode and the metal disc that covers the burner. If the metal disc is slightly off-center, no spark will occur. Check to make sure that the gap between the igniter and the nearest metal is about the same as the back burner.
Jul 25, 2009 | Kitchen Ranges
Magic Chef Range in camp trailer, pilot light in the oven works however, the burner will not light when turned on. No gas flows. Propane furnace works ok and the propane bottle is full. The surface burners...
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
or
May be the ignitor, replaced mine and it fixed it. A gas company guy told me that is common in Magic Chef ranges.
Thanks for contacting Fixya
Jun 14, 2009 | Tappan MGF500PBW Gas Kitchen Range
GE Profile Gas Range oven light doesn't work even after changing
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore gas range
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
Nov 06, 2008 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
Gas kitchen range
Most problems with gas ranges have to do with the flame--either it isn't quite right or it's nonexistent. Most new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners. If, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
Jan 18, 2006 | Crosley CE35100AA Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
