Question about Makita HP1621FK 5/8" Hammer Drill Kit with L.E.D. Light
Keyless chuck removal
Destroyed the KEyless chuck...unable to get chuck screw out...tried metric/ SAE allens, Torx, phillips Does it even have a chuck screw? Really hard for me to see down inside. Any ideas?
  • 2 more comments
  • keelingconst Sep 23, 2008
    I was thinking that might be the case...I'm gonna have to find some kind of spanner wrench to hold the spindle so I can unscrew the chuck. Any Ideas there? Do you think I can get a regular Keyed chuck to go back on? I'm thinking a keyless chuck on a hammer drill is a bad idea.
    thanks for your input
  • keelingconst Sep 24, 2008
    Thanks a lot..worked like a charm once I figured out how to hold the spindle. You da man!
  • steele49 Dec 27, 2008
    How to remove and replace keyless chuck on Makita screw gun.
  • yadayada
    yadayada May 11, 2010
    Do you know the chuck screws off??
    Top Expert:
  • Makita Master
  • 79,851 Answers
Yes you can use any kind if chuck as long as the thread that attachs it is the same size, look on line lots of tool stores sell them cheap.
Posted on Sep 23, 2008
How do i remove a keyless chuck from a Craftsman 19.2 volt 2-speed drill
Inside the chuck you will find a screw (probably torx) this is a left hand screw (Remove clockwise)
Insert a 1/2" allen key into the chuck and using a hammer strike it to spin the chuck off (Standard thread - Counter-clockwise)
Mar 09, 2015 | Craftsman Drills
My keyless chuck will not tightten all the way closed....seems to catch on something
Open the chuck and see if the screw inside the chuck has backed out. The screw is left hand thread so you will need to turn it to the left to tighten it. It may be an allen or Torx head screw.
Jul 15, 2011 | Milwaukee 2690-24 18-Volt Hammer-Drill,...
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
Is it a torx or allen head screw that holds the keyless chuck on a Dewalt Cordless Drill model # dw959. If it is a torx, what size is it ? Is it a right or left handed thread ?
don't know the sizes for the screw but it is the wrong way threads. when you get that out you need a very large allen wrench in the chuck and tight. lay the drill body on a work bench and hit the allen wrench hard to break it loose. it unscres normally.
Aug 29, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Need to change a keyless chuck
open jaws for large size bit.look in bottom and there will be a screw slot or phillips head screw or possibly an allen head screw.remove this,by possibly turning clockwise. and then chuck up a large allen wrench. try removing the chuck by tapping wrench with hammer. this may be threaded on counterclockwise.have to try both ways.
Aug 28, 2009 | Craftsman 19.2v 3/8"drill/driver W/ Work...
Can't remove the chuck retaining screw.
The screw is a LEFT HAND THREAD and also is LIKELY a Metric size!
Make sure you use a Metric Allen wrench.
Jul 08, 2009 | Makita 6408K 3/8" Variable Speed,...
Place drill in vice with chuck in vice facing up . Clamp chuck lightly but with enough force to hold firmly.
put allen wrench in chuck and lightly tap down to make good fit to allen screw head.Clamp chuck jaws down onto allen wrench lightly to hold wrench steady. Take piece of pipe to end of wrench,10".
These chuck screws are tight. Hammer clockwise until screw brakes loose.Open chuck completely and remove screw.Chuck is threaded to spindle shaft . Place allen wrench with long end facing out of tool in chuck and tighten chuck securely. With hammer tap allen wrench sharply counter clockwise ( normal thread.)
Jul 08, 2009 | Makita Drills
Having trouble removing keyless chuck from 18V DC759
Inside of chuck you have a screw, remove screw then tighten an big allen wrench into chuck, short side in, then hold drill and hit allen wrench with a hammer quickly, should break chuck free.
Jun 19, 2009 | Dewalt 18 Volt Compact Drill Kit
Can't get the keyless chuck off cordless Makita 6095D drill.
If this is a newer tool it is probably a Torx drive screw usually a T20. The screw is LH thread and after removing it you will need to put some screws back in tool to remove the chuck. First shift the gear selector to the low setting and the clutch to the drill only. Next get a bent handle allen wrench about the capacity of the chuck install the short end of wrench in chuck and tighten. Put the chuck on a block or wood or a workbench to support is and turn the wrench to about a 30 degree angle in the counterclockwise position. The chuck has standard threads so you want to hit the wrench with a hammer to loosen it. This might take a few tries but it will work. Good luck
Dec 31, 2008 | Makita 12V Cordless Impact Driver -...
Drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Makita HP1621FK 5/8" Hammer Drill Kit with L.E.D. Light  Logo
487 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
