Question about Acer Aspire 5100 Notebook
Disc drive wont work
I have an Acer 5100 series, lately my laptop will not read any discs, when i put in a CD the light blinks yellow a few times and then just goes black. when i check it says its working properlly. i have cleaned the lens and that didnt change the anything.
  • 37 Answers
It sounds like the laser may have went out. When reading a disc the laser moves up and down as well as back and forth. It sounds like it is reading from the wrong position if it's reading at all. Remove any disc from the drive. Go into the device manager and remove/uninstall the drive from the list. Reboot the computer, wait until the hardware wizard reinstalls it and then try reading another disc. If this doesn't help then most likely the laser has went bad. It is not an uncommon problem. You can also see if there is a firmware update for your drive from the maufacturers website or your PC speciffic website. Hope this helps.
Posted on Sep 23, 2008
Why wont my cd drive work
see this and fix it. God bless you
Turn on your computer and open the CD drive by pressing a small button on the front of the drive. Use a can of compressed air to clean the lens by spraying a few squirts of the air into the drive. This will fix disc skipping if there was dust on the lens.
  • 2 Place a CD drive cleaner into the disc drive. This is a disc that is specifically designed to clean CD drives. Allow it to run for a few minutes, and then extract the disc from the optical drive.
  • 3 Click the "Start" button and then click on the "All Programs" option. Click on the "Windows Update" icon and then click the "Check for Updates" button on the left side of the screen. Click the "Install Updates" button at the bottom of the screen to update the drivers for your CD drive. Restart your computer for the driver changes to take effect.
  • 4 Unplug the power cable from your computer and use a screwdriver to open the tower door. Locate the CD drive cables inside the computer. Make sure that the CD drive cables have not loosened. If the cables are loose, then the drive will not operate properly.
  • Sep 27, 2012 | Acer Computers & Internet
    My Toshiba Model L505-S5993 laptop won't read
    Hello there,
    The problem is that the Drives lens is already bad and cannot read any disc, no matter the type of disc you put into it, it wont read it still. The solution is to replace the drive. Replacing it is the best way to solve the problem. If not trying to replace the lens is going to be futile as the lens for the driver is not available and when you install a new disc drive, it will have to install the drivers software.
    If you replace the lens, the laptop wont be able to install the drivers of the lens as it reads it alongside the driver itself and if they are not compatible, it wont install the drivers software. So my best advice is for you to replace the CD drive.
    My laptop is a typical example because my disc drive is also bad. And i had to replace the drive and not the lens.
    Hope this was helpful to you.
    Goodluck
    Elect_Comp
    Aug 09, 2011 | Toshiba Satellite L500 Series Notebook
    CD drive not detected
    I think somehow you've turned your CD drive off in BIOS. Turn it on again (if you don't know how to do it, post yout BIOS version, I'll try to help. BIOS version shows somewhere on the screen when you just turn on your computer. For example "AwardBios v.XXXX)
    Mar 14, 2009 | Acer Aspire 5100 3010 Notebook
    Acer Aspire 5100 no longer "sees" its cd/dvd drive- anywhere.
    You can check the BIOS to see if the drive is recognized and even attempt to boot from the drive using a bootable CD to verify it is functional (if using the Windows disc - just verify it reads - DO NOT REINSTALL)
    If the drive works use the following to get the drive back in Windows:
    Always backup your registry before editing and use care to find exact key!
    Start Registry Editor (Start, Run and type in regedit then click)
    Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
    Quit Registry Editor.
    Reboot.
    NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
    Dec 21, 2008 | Acer Aspire 5100 Notebook
    Acer 5100 cd/dvd drive no longer appears as a device - anywhere
    try a disk cleaner it might be dirty inside and they are very sensative
    CD drine issue
    To manually open the CD Drive, straighten a paper clip and insert it into a tiny hole in the front of your CD drive and push the paper clip gently into the drive and the tray should then pop open.
    Open and close this several times, then insert a disc into the drive and see if it will read the disc.
    If not the drive is dead and needs to be replaced.
    Nov 18, 2008 | Acer (KV.16X04.007) DVD Drive
    Reinstalled windows xp profesional after hd crash. Did not have the original acer aspie 5100 recovery disc to install. Now the cd dvd rom is not recognised by laptop
    if you originally had Vista on then the bios is updated from the older XP bios and wont see the drive, check here for bios downloads, or put Vista back on.
    If you have a full XP disc you will need to do a full format and installation, do not use somebody elses restore disc as it's not the complete windows that you will need.
    Aug 31, 2008 | Acer Computers & Internet
    Cd/DVD drive has stopped working
    ur dvd drive lanse has been week u have to change the lanse
    Aug 04, 2008 | Computers & Internet
    My dual layer DVD burner wont read any media
    When was the last time you cleaned the dust out of the laser head? Or your PC, for that matter? Just asking.
    There are cleaner disks that work sometimes, or you can go in with a cleaner foam swab with a little alcohol on it. Worth a try.
    Apr 08, 2017 | LaCie (300978) DVD RW Dual Layer Burner
    DRIVE UNIT WONT OPEN OR EJECT
    You can eject the cd by pushing a paper clip into the small hole in the draw.
    Sep 26, 2007 | Acer Aspire 5100 Notebook
    Acer Aspire 5100 Notebook Logo
    Mohammed Ebrahim M
    Mohammed Ebrahim M
