You probably want to measure everything except the starter motor current. There is usually a terminal block somewhere on the fire wall. The amp meter is connected in SERIES with the wire where a voltmeter is connected in PARALLEL (across) the circuit.
if I remember right the alternator has a large red wire on the back that goes to the battery ,it goes in it just cut and run two wires to the amp gauge must be the same size as the wire you cut 10 gauge I beleive
heater flares and expels smoke rings every second or so. It smells like too much kerosene in the...
(More)
heater flares and expels smoke rings every second or so. It smells like too much kerosene in the air.
Robinair model 34700Z / There is power on the system , Fan is working , both circuit breakers tested...
(More)
Robinair model 34700Z / There is power on the system , Fan is working , both circuit breakers tested okay but THERE IS NO DISPLAY ON CONTROL MODULE.
