Aficio 1224c copier sc 571
The scanner still works - we moved the copier to another room - no a service code of 571 ? any ideas
  • Tim Babcock
    Tim Babcock May 11, 2010
    I'm going to have to look that one up tomorrow. Didn't come up on the quick ref charts.
  • 2,794 Answers
SC 571 is a fusing error caused by not being seated properly or the oil sensor is coated with oil.
More than likely when the machine was move oil coated the senor in the fuser and it has to be taken apart to be cleaned.
Posted on Sep 23, 2008
  • 1,326 Answers
The error code could a fixing error code, but most likely it is a finishing problem. Does the copier have a sorter or finisher on it? If so, diconnect it from the back of the copier and see if the code goes away. If it goes away, you may have a sensor out of wack when you moved it... Will the finishing bin move to find "HP"? The copier will work with out the finisher connected. You can also try to do this to tyr to clear the code.. Press "yellow" Reset once then the #'s 1 then 0 then 8 don'tr hold them down... next press and hold the "red" Stop/Clear botton till the display changes...... Then turn it Off and then back ON.... It should clear the code.... Good Luck...
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
Mar 01, 2013 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
How do I scan a document from my Ricoh 1224c copier to my computer?
have you installed the driver for its scanner? here's the link http://www.ricoh-ap.com/downloads/GetDriver.aspx?CID=1&pn=Aficio%u2122%201224C&path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/c24_32/c24_32en.htm
Sep 02, 2011 | Ricoh Aficio 1224C Black and White Copier
Hello i have ricoh aficio 1224c color . but the is have problem error sc792 . please help me best regards Salar
SC 792 :Finisher error .
The machine does not recognize the finisher , but recognizes the relay unit .
Possible causes :Defective connector
defective cable
incorrect installation
Aug 10, 2011 | Ricoh Aficio 1224C Black and White Copier
How to decode Ricoh (Aficio) 1224c with code sc 670 from my color copy mactine....
In the service mode (clear modes 107 hold down clear/stop key) then punch in 7807 on the number pad then execute to reset the sc 670, if it doesn't clear you may have a bad controller board or HDD. Hope this helps
Aug 03, 2011 | Office Equipment & Supplies
Ricoh (Aficio) 1224c. code sc670 we want to decode this codesc670
Hi, it looks like a bad controller board. Try resetting it from in service mode with 7807. Also if you can view or printout the error history with 5990-004 for further trouble shooting. Hope this helps
Aug 03, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh aficio 3232c SC 571
ricoh aficio 3232c eror code sd 195
Aug 02, 2011 | Ricoh Aficio 2232C Color Copier
Ricoh Aficio 1224c error code SC 544
Well, I have no idea why changing your password would affect it this way. the code you're experiencing is a fuser warm up error, due to blown fuse, thermostsat, possible power supply prob...regardless, it can only be reset by a service tech in service mode once the problem is fixed. Sorry.
Mar 05, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 1224C/1232C problem code SC 792
Hello sir; try to turn off and back on the machine to reset, if don't work next few steps need to follow;
1, press "clear mode" then enter 107 then press and hold "clear/stop" key until SP mode show up.
2, turn power off and back on .
Jan 09, 2009 | Office Equipment & Supplies
Sc 481 on my ricoh aficio 1224
moz-screenshot.jpgmoz-screenshot-1.jpgThe problem (s) could be; defective main motor, image transfer belt out of position, belt mark blurred or absent.
A ITB belt inspection and/ or repair would be a job for tech.
Or you could just order a new PCU which would fix the problem.
Jan 08, 2009 | Ricoh Aficio 2015 Copier
Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Jun 18, 2008 | Office Equipment & Supplies
368 people viewed this question
k24674
jasbo
jasbo
