Maths convert 0.9 L into cL
  • 27 Answers
Asuming you mean cL to mean centilitres then seeing as there are 100 centiltres in a litre you would simply multiply 0.9 by 100 which equals 90 centilitres.
Posted on Sep 24, 2008
Why when -2x divide x = math error
I think the problem with this equation comes when x = 0. At this point, it is undefined. Thus, it is a horizontal line y=-2, except when x=0. This is normally signified by putting an open circle when x=0.
I hope I answered you question. If not, repost.
Good luck,
Paul
Sep 09, 2016 | Casio FX-82MS Scientific Calculator
Convert decimal fraction to binary
None of these solutions answer his question. When converting a fraction or any number with decimal places to Binary, the TI-89 gives "Error: Domain error." For example, entering .6875 [2ND][MATH][BASE][BIN] does not work. I haven't found a way to do it with built in functions. In order to do these types of conversions, I use the following method.
Convert: 0.6875 to Binary
- left of decimal is a 0, so write down a 0, then a decimal point: (0.)
- multiply .6875 x 2 = 1.375 left of decimal is 1, write a 1: (0.1)
- drop the 1 and multiply .375 x 2 = .75 left of decimal is 0. write a 0: (0.10)
- multiply .75 x 2 = 1.5 left of decimal is 1, write a 1: (0.101)
- drop the 1, multiple .5 x 2 = 1. left of decimal is 1, write a 1: (0.1011).
- since there is no more fraction, the final answer is (0.1011). Hope this helps.
Jan 27, 2012 | Texas Instruments TI-89 Calculator
What is the graph of y=squareroot of x2 - 2x
hi.
i am assuming this is to do with programming the machine or a maths question in the wrong section.
fortunately i was always good at maths.
the graph shown will be a straight line.
x2 and 2x are the same thing. so x2-2x will always = 0. square root of 0 is 0
y will always = 0 no matter what x is.
hope this helps
Jun 29, 2011 | Sewing Machines
Find each value? 2! 0!
2! = 2
0! = 1
The factorial command is in the MATH/PRB menu. Press MATH, then left-arrow.
Mar 27, 2011 | Texas Instruments TI-83 Plus Calculator
5th root of i
5 2nd [MATH] F5 MORE F4 ( 0 , 1 ) ENTER
2nd [MATH] brings up the Math menu. F5 goes to the Misc menu, and F4 is the x-th-root function. ( 0 , 1 ) puts in the complex number i: that is a real component of 0 and an imaginary component of 1.
Nov 17, 2010 | Texas Instruments TI-86 Calculator
Where is the fraction key on this calculator?
There isn't one. You can convert some values to fractional form by using the >Frac command on the Math menu available by pressing the MATH key. You can enter a fraction as a quotient, but the calculator deals with the number internally by converting it to decimal form.
For example, to see one-half plus one-third, press
( 1 / 2 ) + ( 1 / 3 ) MATH 1 ENTER
Nov 05, 2010 | Texas Instruments TI-84 Plus Calculator
Need codes to program a Curtis Mathes television for the RCA RCR311BI control
try these codes they should work or onbe of them should!
Cu tis Mathes 0 0 4 7 ,0 7 4 7 ,1 1 4 7 ,1 3 4 7 ,0 0 5 4 ,0 1 5 4 ,
0 0 5 1 ,0 4 5 1 ,0 0 9 3 ,0 0 6 0 ,0 0 3 0 ,0 0 5 6 ,
0 1 4 5 ,0 0 1 6 ,0 1 6 6 ,0 4 6 6 ,0 0 3 9
Please rate my help++++Thanks for using FIXYA
May 20, 2010 | RCA RCR311B Remote Control
My problem involves converting in chemistry and im just trying to figure out how to do a problem 0.58 x 6.022 x 10 raised to the 23/ 1. I know how to calculate the problem just cant read the answer a more...
Press the keys:
. 5 8 * 1 2 . 0 1 x^-1 * 6 . 0 2 2 2ND [EE] 2 3 ENTER
and you should get 2.9E22. Do you get something different?
* is the multiply key on the right, between divide and subtract.
x^-1 is on the left, below MATH.
EE is the 2ND function of the , key, just above the 7.
Another way to calculate this is:
. 5 8 / 1 2 . 0 1 * 6 . 0 2 2 2ND [EE] 2 3 ENTER
This should give you the same result.
Mar 10, 2010 | Texas Instruments TI-83 Plus Calculator
Where is the fraction button on the ti 83 plus cac. look like
There is no fraction button. Any division of two integers you do is represented as a decimal number. If you want your fraction to remain a fraction you enter it as follows
7[ / ] 19 [ MATH][1:ToFrac] [=] displays 7/19
If you want to convert a decimal number into a proper fraction press [MATH][1:ToFrac] .
Exemple 7/19 [ENTER] gives .36842105. If without doing anything else, you press [MATH][1:ToFrac] you recover 7/19.
There are limitations related to the number of decimal digits in the floating point number.
.3684 [MATH][1:ToFrac][=] gives 921/2500 but
.36842 [MATH][1:ToFrac][=] gives .36842 : it is not converted to fraction.
Hope it helps
Sep 16, 2009 | Texas Instruments TI-83 Plus Calculator
Java code for adding octal, hexadecimal subtracting binary,
Hello desireejane,
One method is to do the following
  1. Convert the octal, hexadecimal or binary to decimal.
  2. Add or Subtract the decimal normally
  3. Convert the result back to octal, hexadecimal or binary.
  • Convert the octal to decimal:
public static long octalToDecimal(String octal) throws NumberFormatException {
// Initialize result to 0
long res = 0;
// Do not continue on an empty string
if (octal.isEmpty()) {
throw new NumberFormatException("Empty string is not an octal number");
// Consider each digit in the string
for (int i = 0; i < octal.length(); i++) {
// Get the nth char from the right (first = 0)
char n = octal.charAt(octal.length() - (i+1));
int f = (int) n - 48;
// Check if it's a valid bit
if (f < 0 || f > 7) {
// And if not, die horribly
throw new NumberFormatException("Not an octal number");
} else {
// Only add the value if it's a 1
res
+= f*Math.round(Math.pow(2.0, (3*i)));
return res;
Mar 24, 2009 | Sun Java Programming Language (cdj-275)
52 people viewed this question
jasbo
jasbo
